Chain Lube - Kawasaki Versys Forum
post #1 of 9 (permalink) Old 06-18-2008, 06:56 PM Thread Starter
Scubs17934's Avatar
Chain Lube
The owners manual says to lube the chain every 400 miles with 90W gear oil. However, the bike came new lubed with the wax type lube. I know if I use the gear oil it will make a heck of a mess with fly off. What have you guys been using?
Scubs17934 is offline
post #2 of 9 (permalink) Old 06-18-2008, 10:18 PM
Maxima Synthetic Chain Guard
post #3 of 9 (permalink) Old 06-18-2008, 10:30 PM
hello scubs,
installed the scottoiler from day one n chain has thin film of oil on it all the time. was using motul chain lube on the VT600 previously, but the sticky goo left behind on the front sprocket n rear rim was a right mess. check it out at their website www.scottoiler.com
rgds
myred is offline
post #4 of 9 (permalink) Old 06-19-2008, 07:24 AM
Guest
If you dont do any offroad riding then you can use a chain wax , but for on and offroad rather use a chain lube .
Shawn is offline
post #5 of 9 (permalink) Old 06-28-2008, 04:42 PM
Guest
I've used this Alisyn product on many bikes for many years with stellar results. In fact I've never had to replace a chain or sprockets on a bike that I've used it on.
http://aerospacelubricants.thomasnet.com/viewitems/market-motorcycle/alisyn-synthetic-chain-lubricant?&bc=100|1005|3001057&forward=1
astroturf52 is offline
post #6 of 9 (permalink) Old 07-01-2008, 01:30 AM
How many miles on the bike/chain you didn't replace in how many years?
Gustavo
Gustavo is offline
post #7 of 9 (permalink) Old 07-03-2008, 07:15 PM
hacktracker's Avatar
When I apply chain lube, I do it at night after a ride and then it sorta dries overnight and much less flings off.
That's my $0.02
Don
Don
"ride more, worry less"
2000 Honda VFR800 - Street
hacktracker is offline
post #8 of 9 (permalink) Old 07-03-2008, 08:20 PM
Guest
I've been using Dupont Teflon Multi-Use Dry, Wax Lubricant.WebBikeWorld & MCN both rave about it. You can get it at Lowes for about $5.00 for a 11oz. spray can.
augie is offline
post #9 of 9 (permalink) Old 07-07-2008, 11:57 PM
Guest
I've been using the same stuff with good results so far, make sure to clean the chain well before using it, I like that it dries quickly and does not leave a oily mess afterwards to clean.
Tried chain wax a while back, but found that it really attracted dust and dirt and felt that it probably wasn't doing the chain any good with all the grit.
Mi dos centavos,
Zeniac is offline
Similar Threads
chain adjustment edthe Technical Discussion - V-650 15 10-30-2008 12:48 PM
Chain Replacement spfduck Technical Discussion - V-650 17 10-17-2008 06:10 AM
chain lube - autozone vladimirpoopen Technical Discussion - V-650 54 09-07-2008 11:27 AM
cleaning the chain! novice Technical Discussion - V-650 7 08-23-2008 08:49 PM
Chain Maintenance/Chain Replacement dstarman Technical Discussion - V-650 0 05-04-2008 12:43 AM
