WOLO Bad Boy Horn at Harbor Freight - Kawasaki Versys Forum
post #1 of 10 (permalink) Old 08-10-2009, 11:53 AM Thread Starter
This horn LOOKS identical to the Stebel Nautilus. Has anyone heard BOTH so they could give me a comparison of them? the link to the WOLO:
http://www.harborfreight.com/cpi/cta...emnumber=94117
Thanks,
post #2 of 10 (permalink) Old 08-10-2009, 02:25 PM
They are identical. I took a broken Nautilus off of my KLR and replaced it with a Bad Boy (because it was available down the street and I had to order a Nautilus). Bad Boy is be appearance, the same horn. Just as LOUD too.
And I have the Bad Boy on the Versys also.
Bob
COBOB is offline
post #3 of 10 (permalink) Old 08-12-2009, 03:36 PM
LAVersys's Avatar
Wondering where you mount this "Bad Boy"?
Picture(s)?
Current bike
09 Kawasaki Versys
Previous bikes
07 Suzuki GSXR 1000
07 Yamaha FZ1
06 BMW K1200 GT
05 Suzuki Vstrom 650
01 Yamaha Vstar 650
90 Yamaha FZR 600
7x Yamaha Enduro 125
LAVersys is offline
post #4 of 10 (permalink) Old 08-12-2009, 08:58 PM
Picture(s)?
I mounted a Stebel on the same bracket that the OEM horn used. Took a little bending in a vise and a few stainless steel washers for spacers to make it fit but fit it does. It faces forward and down so the sound points where you want and and water that sprays off the road can drip out. Don't forget to run a loop of hose from the air intake so liquid isn't sucked inside...under a buck at your local hardware store. Take the fitting with you so you get the right diameter.
Some other people have split the compressor from the trumpets and mounted them under the red cowl on either side of the fuel tank.
[SIZE="1"]Ride. Good.
2019 F750GS
2014 R1200RT
2008 Versys (SOLD 11/19)
2003 ST1300ABS (SOLD 5/15)
post #5 of 10 (permalink) Old 08-14-2009, 01:57 PM
I have mine on the left side, between the fairing and the tank. Did not have to split the horn or anything. It takes a little while to figure out a bracket for mounting, but it fits like a glove and does not contact anything. Being down there, tucked away, does not affect the sound at all. I left the stock horn where it was, just not hooked up.
Sorry, I did not take pictures as there are a bunch posted here and on other sites. A search should get you there.
COBOB is offline
post #6 of 10 (permalink) Old 08-14-2009, 02:13 PM
bscott's Avatar
I bought the WOLO from HF yesterday. (20% off coupon).
I tested it in the garage with my car battery charger. Just about dropped the damn thing, it was so loud!
I've got the compressor and horn separated, and am attempting to mount both parts on either side of the headlight under the fairing.
A friend mounted a Nautilus upside down and has had two failures in short time.
I think it is the compressor that likes correct mounting, but maybe that is only for air intake reasons (think water drain).
2008 Versys, SOLD!
2002 BMW R1150RT Lovin it!!!
bscott is offline
post #7 of 10 (permalink) Old 08-17-2009, 08:18 AM
bscott's Avatar
Side-by-side comparison of the Wolo on my bike and the Stebel Nautilus on a friends bike, they sound the same.
I ended up mounting mine in the stock location using the original horn bracket. I also had to straighten it in a vise, and I believe that I turned it over as well.
2008 Versys, SOLD!
bscott is offline
post #8 of 10 (permalink) Old 08-23-2009, 10:40 PM
Guest
Ratesunion is offline
post #9 of 10 (permalink) Old 08-25-2009, 09:32 AM
Mounting the pump on the correct angle is a must. It has a little bit of oil in it. Without the oil in the right spot it will fail.
09 V Metalic Moondust Grey Leo Vince Slip-on, Speedy's lowering pegs and kick stand pad, Kappa K33 saddle bags, SW-Motech Quick attach racks, CF Hugger, Fenda Extenda, Vario Windshield
Dr.Das is offline
post #10 of 10 (permalink) Old 03-21-2010, 09:38 PM
StonedGP's Avatar
Picture(s)?
Look at fasteddiecopperman's mounting point. I just copied his setup. Out of the way and rain. http://www.kawasakiversys.com/forums...ghlight=stebel
StonedGP is offline
