Bike won't start - Kawasaki Versys Forum
post #1 of 8 (permalink) Old 08-04-2009, 02:57 PM Thread Starter
Send a message via Yahoo to jovial73
Question Bike won't start
Howdy all!
I've noticed the past two weeks my V won't start unless it's in N. I haven't done anything to it and I don't think anything has changed.
Usually I hop on when I'm headed out, put the stand up, hold the clutch in and start. Now I do all that and get nothing. When I pop it up the N it'll start and all's well. The Stand switch and Neutral switch are both good -- tested them both. Could it be a clutch switch issue? Has anybody else had this problem?
I got the V second hand in May and have put about 600 miles on it (1200 total). It is stock.
Thanks, J
jovial73 is offline
post #2 of 8 (permalink) Old 08-04-2009, 05:04 PM
Could be. Or could it be your side stand switch needs adjustment?
post #3 of 8 (permalink) Old 08-04-2009, 05:19 PM
Mine won't start up if it isn't in neutral. Its a brand new bike. I'm pretty sure that's how its supposed to be so you don't start it and flip your self off the bike.
mcampana is offline
post #4 of 8 (permalink) Old 08-04-2009, 05:24 PM
They will start in gear if your sidestand is up. I have killed the bike at stop lights
and it always starts in gear.
post #5 of 8 (permalink) Old 08-04-2009, 10:12 PM
+1, I've done the same and it starts in gear.
Randy49 is offline
post #6 of 8 (permalink) Old 08-04-2009, 10:30 PM
Pepe's Avatar
I usually start it in gear, with the clutch engaged. It has to be fully engaged though, could be that you're not fully engasging it?
Pepe is offline
post #7 of 8 (permalink) Old 08-05-2009, 10:42 AM Thread Starter
Smile Never mind
I hopped on last night and before starting happened to peer over the bars and saw the electrical plug on the left side going to the clutch switch... I pushed it and heard a 'click'. In 1st the bike started up fine with clutch in.
I've looked over that at least twice during my weekly walk around, but hadn't pressed it. I guess I need more sleep.
jovial73 is offline
post #8 of 8 (permalink) Old 08-05-2009, 05:05 PM
Glad you found the problem!
Tags
clutch, neutral, start, switch
