Valve Tapping - Kawasaki Versys Forum
post #1 of 22 (permalink) Old 08-02-2009, 10:41 PM Thread Starter
Red Herring's Avatar
Valve Tapping
Well... 18,000KM on the bike. Not too much, but on my way home tonight I got something I had not heard in quite a while. Coming around a corner in 3rd, at ~2800 RPM, and laying on the go juice, I heard the cacophony of my valves rattling. Disturbing. I do ride it pretty hard, but maintain it like mad. Only happens under strain from accelerating hard in low RPM. I thought it would last longer before the valves needed adjusting. Booo!
Red Herring is offline
post #2 of 22 (permalink) Old 08-02-2009, 10:54 PM
What gear were you in?
Nevermind, 3rd gear I see after re-reading it...
post #3 of 22 (permalink) Old 08-02-2009, 11:15 PM
Just went over 20,000 miles on my bike and mine have been tapping for awhile. I took mine to the dealer at about 17,000 and they told me they were in tolerance. It sure does sound like crap to me though but runs fine. I guess I'll take it back at 25,000 or do it this Winter whatever comes first.
jimstandinghorse is offline
post #4 of 22 (permalink) Old 08-02-2009, 11:16 PM
Sounds more like pre-ignition, valves just don't become loose all of a sudden. I sometimes hear the same thing under those condtions. Upgrading the fuel octane helps but doesn't stop it completely. Just go down another cog before dropping the hammer.
mcrider is offline
post #5 of 22 (permalink) Old 08-02-2009, 11:32 PM
I always run 93 octane and my bike has been making a noise for awhile. I took it to the dealer to have the valves checked and they said they were in tolerance. They said there was nothing to worry about but I don't like the noise it makes. According to the dealer there is nothing wrong.
post #6 of 22 (permalink) Old 08-02-2009, 11:52 PM
Are you happy with your engine oil?
Maybe a slightly thicker viscosity while help with the valve tapping.
Sure its not the camshaft chain? Maybe the chain tensioner has to be loosen and re-torqued.
Good Luck.
post #7 of 22 (permalink) Old 08-03-2009, 12:55 AM
The oil viscosity doesn't make a difference as I tried that. What you said maybe a possibility. All I know is that it started in the Winter when I started my bike up and did something I shouldn't have done (rev the engine up to high). It instantly made a different engine noise and has been that way since. I took it to the dealer and they said there was nothing wrong with, changed the oil and filter, and charged me like $65.00. I took it back before the warranty ran out.
post #8 of 22 (permalink) Old 08-03-2009, 01:33 AM Thread Starter
Good Luck.
Naw... it's valve clatter. Just started today. I will see if higher octain gas makes a difference, but I doubt it. It has run fine on regular so far.
post #9 of 22 (permalink) Old 08-03-2009, 05:48 AM
That really does sound like pre-ignition from a batch of low-quality gasoline, and maybe also from long-term carbon buildup in the combustion chamber.
post #10 of 22 (permalink) Old 08-04-2009, 10:50 PM
maloy's Avatar
You know the tapping you may be hearing are the cold air flaps on the air intake?
That is why your bike may seem to be working okay.
Maloy
Bikes owned
Current
'74 Honda CL360
Past
'08 Versys (lost in head on collision 07-05-2010)
'86 Honda XL500 (wrecked RIP)
'08 KLR650
'00 Vulcan Classic Fi 1500cc
'06 Kymco 250cc scooter
'93 Honda VLX 600cc
'85 Honda XL500
'85 Honda Rebel 250cc
maloy is offline
post #11 of 22 (permalink) Old 08-04-2009, 10:58 PM
Air intake cold air flaps??
post #12 of 22 (permalink) Old 08-04-2009, 11:13 PM
maloy's Avatar
They are part of the fuel injection system and throttle bodies and act similar to an automatic choke. If you have access to a service manual you can see them in the top image on page 3-103.
Kawasaki uses a similar setup on different models. I had a 1500 Classic Fi that you would swear needed a valve job because they were so lowed.
Maloy
Bikes owned
Current
'74 Honda CL360
Past
'08 KLR650
'93 Honda VLX 600cc
'85 Honda XL500
maloy is offline
post #13 of 22 (permalink) Old 08-04-2009, 11:51 PM
You mean on page 3-102? I suspected that you were referring to the sub-throttle plates. I actually removed mine before I ever started my new Versys...
post #14 of 22 (permalink) Old 08-05-2009, 12:11 AM Thread Starter
You might be right. Filled up with fresh stuff, and I have not heard it again.
post #15 of 22 (permalink) Old 08-05-2009, 04:14 AM
Right on, Red Herring.
Which gas station did the offending 87 pump octane gas come from? What's in it now? You'd probably be ok with 89... I like the extra tractability and mileage I get out of 91 octane, especially with 5 degrees more ignition timing advance.
post #16 of 22 (permalink) Old 08-05-2009, 11:08 AM Thread Starter
I usually only fill from Petro Canada or Chevron. I have notices some knock in my wifes car as well. I wonder if they have been diluting the gas of late?
post #17 of 22 (permalink) Old 08-05-2009, 02:21 PM
So you're still on 87?
post #18 of 22 (permalink) Old 08-05-2009, 02:58 PM Thread Starter
Filled with 94 this time. I hate using the mid grades, because the first 4 liters are whatever the last guy pumped... usually regular. I do like running 91, but usually put in 87.
post #19 of 22 (permalink) Old 08-05-2009, 04:38 PM
maloy's Avatar
Invader,
A lot of people get them removed. Did you have any cold starting issues afterward?
It seems to be a hit and miss for some people.
Maloy
Bikes owned
Current
'74 Honda CL360
Past
'08 KLR650
'93 Honda VLX 600cc
'85 Honda XL500
maloy is offline
post #20 of 22 (permalink) Old 08-05-2009, 06:06 PM
No cold start problems whatsoever with the plates removed.
