Bad Brakes? - Kawasaki Versys Forum
post #1 of 3 (permalink) Old 07-13-2009, 10:05 PM Thread Starter
potus2012's Avatar
Bad Brakes?
The lever on the front brake is so soft it nearly hits the grip when fully squeezed. I have small hands so I have to adjust the knob to 4 to make it useful. Still it will pinch my last two fingers if I try a two finger stop. I also get a "grinding" feel when I get on the front brake moderately. I notice no pulsing at all, and the rotor looks clean with no grooves. I don't notice any brake dust accumulating anywhere either.
I bled the brakes today with little to no change in lever feel. The left caliper bled clean, but the first two squirts from the right caliper were black. Not amber or brown, but black. Didn't notice any air or separated water.
I've got less than 4000 miles on it.
Any ideas?
potus2012 is offline
post #2 of 3 (permalink) Old 07-13-2009, 10:40 PM
oxman's Avatar
sounds like your right side got a little hot and burnt your fluid in the caliper . Are you heavy on the front brakes and if so maybe upgrade to a race spec brake fluid . I use Ferodo fluid
http://www.ferodoracing.com/it/motor...fluid_pads.htm in all my bikes with good results.
oxman is offline
post #3 of 3 (permalink) Old 07-14-2009, 03:56 AM
Hi Potus2012,
3 thoughts:
1. The brake lever plunger seal damaged.
2. Very unlikely but check the brake pad lining thickness.
3. Dirty brake fluid
