Generator Cover Removal - Kawasaki Versys Forum
post #1 of 8 (permalink) Old 07-05-2009, 12:48 PM Thread Starter
cetzel's Avatar
Generator Cover Removal *Solved*
I got a replacement generator cover since I ground mine up pretty good in my spill. What is behind it ? I don't have a service manual and was going to tinker in the garage today. Can I replace it without draining the oil ? Are there strange springs going to fly out and land in inconspicuous places in my garage ?
Yes, I need a good manual. I couldn't find it in the online service manual. I suppose whilst I wait for the combined knowledge of your responses I'll look at the diagram at bike bandit.
Thanks in advance for any insight!
UPDATE: It _is_ in the manual. Page 516. I was looking for "generator" instead of "alternator". Thanks to Machog!
cetzel is offline
post #2 of 8 (permalink) Old 07-05-2009, 12:53 PM
Machog's Avatar
Photo's won't copy from the manual, but here are the 'words'. If 'words' alone aren't enough, PM me and I might have a better idea.
Machog
Alternator Cover Removal •Remove the lower fairing (see Lower Fairing Removal in
the Frame chapter). •Disconnect the alternator lead connector [A].
•Place a suitable container under the alternator cover [A]. •Remove:
Alternator Cover Bolts [B]
Clamp [C]
Bracket [D] •Pull the alternator cover outside.
Alternator Cover Installation •Apply silicone sealant to the alternator lead grommet and
crankcase halves mating surface [A] on the front and rear
sides of the cover mount.
Sealant - Kawasaki Bond (Silicone Sealant): 92104-0004
•Check that dowel pins [B] are in place on the crankcase. •Install a new gasket and the alternator cover. •Tighten:
Torque - Alternator Cover Bolts: 9.8 N·m (1.0 kgf·m, 87
in·lb)
Stator Coil Removal •Remove:
Alternator Cover (see Alternator Cover Removal)
Holding Plate Bolt [A] and Plate
Alternator Lead Grommet [B]
Stator Coil Bolts [C] •Remove the stator coil [D] from the alternator cover.
Machog is offline
post #3 of 8 (permalink) Old 07-05-2009, 12:56 PM Thread Starter
cetzel's Avatar
Machdog, thanks! Is this from one of the manuals we can download from the forum links ?
cetzel is offline
post #4 of 8 (permalink) Old 07-05-2009, 12:59 PM Thread Starter
cetzel's Avatar
Spelling Correction: Machog. Man my dyslexia is working good today. Perhaps I should put the wrenches down.
cetzel is offline
post #5 of 8 (permalink) Old 07-05-2009, 01:09 PM
Machog's Avatar
Yep, that's it.
Machog
Machog is offline
post #6 of 8 (permalink) Old 07-05-2009, 03:24 PM
Manual mentions: "Place a suitable container under the alternator cover [A]" to catch spilling oil when removing the cover... Oil won't spill if you lean the bike enough to the right.
post #7 of 8 (permalink) Old 07-05-2009, 08:30 PM
Hi Cetzel,
If you need the manuals, try http://www.kawasakiversys.com/forums...hlight=manuals
Best Regards.
post #8 of 8 (permalink) Old 07-06-2009, 01:59 AM
You might be able to leave the original undamaged gasket on the case by carefully removing the cover, and seal it back up with a touch of silicone sealant after wiping off any oil, like I did with my clutch/crankshaft sensor cover gasket. Gasket may be well stuck on the engine casing, which is hard to completely clean off without gouging the aluminum and creating a leak... I also removed my Yamaha WR426's generator cover a few times without replacing gasket or adding any silicone sealant, and without dripping any oil by leaning it to the right.
