Shift linkage? New foot pegs - Kawasaki Versys Forum
post #1 of 7 (permalink) Old 06-18-2009, 07:43 AM Thread Starter
zx12's Avatar
Some times(10%) when I upshift from 1st to 2nd the shifter lever doesn't reset so you can go into 3rd. It only has 1000 miles on it (Ive only had it 2 weeks and the Multistrada is jealous). Anyone had this problem. I might have twisted the heim joints a little when I set the lock nuts after lowering the lever for the lower pegs. I put stock Buell (06 Uly) pegs on the bike which lowers the pegs 1 inch.(more comfy for this old codger).
zx12 is offline
post #2 of 7 (permalink) Old 06-18-2009, 04:05 PM
Yeah, an adjustment might help. However, a lot of us complained about the shifting when we first got the bike...
post #3 of 7 (permalink) Old 06-18-2009, 10:27 PM
Had the same problem when fixed my motowerk's lowering peg. Like you, set the lock nut to my liking. Did a few short rides to do the adjustment.
Used a small pipe to bend the shifting lever slightly out to suit me.
Good Luck
post #4 of 7 (permalink) Old 06-19-2009, 06:17 AM
MN_Smurf's Avatar
You're probably not dropping your toe far enough after you shift to reset the shifter....adjust the shift lever up a little. I had the same issue when I got my bike....
MN_Smurf is offline
post #5 of 7 (permalink) Old 06-19-2009, 07:21 AM Thread Starter
zx12's Avatar
Did a few adjustments and took the strain off the heim joints and all is good. Thanks for the input.
zx12 is offline
post #6 of 7 (permalink) Old 06-19-2009, 09:04 AM
kmahorney's Avatar
MN_SMURF hit it right there.
Mine has done it since day one, i am pretty sur it is just the way i shift. I have not put lowering pegs on yet..
kmahorney is offline
post #7 of 7 (permalink) Old 06-22-2009, 06:06 AM
There's a little more to it...
