economical quick prop - Kawasaki Versys Forum
post #1 of 13 (permalink) Old 06-17-2009, 10:44 PM Thread Starter
rbl
I am leaving on a cross continent trip next week and needed a quick and easy solution to lubing the chain (much as I would like a scott oiler it is not in the budget right now). I had a piece of square steel stock leftover from another project, a couple quick cuts, some sanding and black paint resulted in this:
it is cut to slip over the spool on my lower swingarm
I may build another out of aluminum but this will do the trick for this trip. I've added a piece of velcro to lock the front brake during use.
RBL
07 Versys, orange.
givi e21's & pelican 1550
warm&safe dual heattroller
fender extender (unknown brand)
rear hugger
madstad bracket
vario windscreen
handguards (dr650?)
klr front and rear signals
hb crashbars
flatfoot
lowering pegs
ctech fuse panel
rbl is offline
post #2 of 13 (permalink) Old 06-17-2009, 11:46 PM
I did the same thing with PVC pipe. A tee fitting on the top end cut out to accept the bobbin. Very light weight and compact.
Hipshot is offline
post #3 of 13 (permalink) Old 06-18-2009, 12:31 AM
bscott's Avatar
I do the same thing with a piece of dowel rod from a closet project. I've got a v-cut in one end. It works great for me on the road. Done it for years.
For all the nay-sayers that wring their hands every time this comes up and say it's a , I'd like to see how you carry your track stand with you on the road...
2008 Versys, SOLD!
2002 BMW R1150RT Lovin it!!!
bscott is offline
post #4 of 13 (permalink) Old 06-18-2009, 11:52 AM
Machog's Avatar
My take on it.
I never got round to getting sliders, so I use a 10mm bolt.
Machog
Machog is offline
post #5 of 13 (permalink) Old 06-18-2009, 04:12 PM
amir_zwara's Avatar
I have one almost exactly identical to Machog's.... infact, I stole the idea from him!
Hope you don't mind buddy
amir_zwara is offline
post #6 of 13 (permalink) Old 06-23-2009, 07:51 AM
Doctor Shifty's Avatar
There's a commercial prop like this that has two legs and a little lever to set it up. I'm cheap enough to use a concretor's wooden smoothing float, just the right height if I sit it on a piece of paving offcut. :-)
Doctor Shifty is offline
post #7 of 13 (permalink) Old 06-26-2009, 09:04 PM
Machog,
Would you please give us the exact specs on the 10 mm bolt? I was over at my local hardware store today and got a 10 mm bolt, but it doesn't seem to fit in the hole in the swingarm.
mlablan1 is offline
post #8 of 13 (permalink) Old 06-26-2009, 09:28 PM
I think you need 10mm threads, not head.
Shatrat is offline
post #9 of 13 (permalink) Old 06-26-2009, 11:27 PM
This is what I use, slides together only about 10 inches long when in shortest position.
I made it , but copied some one else's design.
2008 Concours
2008 Versys
Restored 69 Honda Trail 90
Whizzer motorbike
august is offline
post #10 of 13 (permalink) Old 06-27-2009, 12:12 AM
Thanks, Guys for the Excellent ideas.
post #11 of 13 (permalink) Old 06-27-2009, 12:34 AM
Machog's Avatar
mlablan, its 10mm fine thread bolt (there are two thread counts on metric stuff, fine and coarse). Most hardware stores carry them, probably in stainless or chrome.
Machog
Machog is offline
post #12 of 13 (permalink) Old 06-27-2009, 07:59 AM
A 1" piece of square tubing works fine and is lighter than most of the ones shown. It fits over the little downward dimple on the swingarm.
rronald is offline
post #13 of 13 (permalink) Old 06-28-2009, 07:41 PM
Machog,
Thanks for the info - I will be heading back to the hardware store in a day or so.
Thanks again.
mlablan1 is offline
