Instrument cluster compatibility between Versys and ER-6/Ninja? - Kawasaki Versys Forum
post #1 of 4 (permalink) Old 06-17-2009, 06:14 PM Thread Starter
Hi,
Has anybody ever swapped their instrument panel for one off another bike? Just wondering if the wiring is the same and all the functions are retained.
The one on my ER-6 is broken and this would open increase my chances to find a used one.
Cheers,
Lukas
LukasM is offline
post #2 of 4 (permalink) Old 04-05-2020, 10:56 AM
Klavs Vabulnieks's Avatar
Bump!
I would be interested in this same question. I kind of ruined my instrument cluster as well.
--- Kawasaki Versys KLE650 2007 Burned Candy ---
Klavs Vabulnieks is offline
post #3 of 4 (permalink) Old 04-05-2020, 11:46 AM
Cluster / Different Kawasaki Models
OEM ER6N instruments, same features as the Versys instruments but in a much more compact package protected by an OEM cover on the back. same basic electrical connections, it's connected to the OEM Versys fuel level sending unit, for instance.
Originally Posted by alfasteve View Post
Gotta ask, my '09's instrument panel has non-functioning mode buttons. They simply don't seem to last. Is this instrument panel more robust in that regard? I don't feel like spending money for a new stock dash if it's going to fail again.
Thank you,
Steve
i've used several different versions of the Kawasaki panel on various bikes for over 100K miles, some very adverse conditions along the way, no failures or problems of any kind. don't know why you're having problems with your particular Versys panel, but it wouldn't hurt to inspect the multi pin main connector, grease and reconnect if you haven't done it already. also, the panels are often found used for a decent price.
I can only quote but the pin configuration does change on various models as does the connection method.
post #4 of 4 (permalink) Old 04-05-2020, 11:46 AM
Originally Posted by Klavs Vabulnieks View Post
Bump!
Good question, MK-1 will not work on MK-2 as far as I know, they changed the power supply for the sensors and that affects the cluster.
Look here as well https://www.kawasakiversys.com/forum...41-post60.html https://www.kawasakiversys.com/forum...77-post63.html
https://www.kawasakiversys.com/forum...55-post65.html
from https://www.kawasakiversys.com/forum...-versys-2.html
