Ethanol on gas... - Kawasaki Versys Forum
post #1 of 25 (permalink) Old 09-16-2013, 02:53 AM Thread Starter
Ethanol on gas...
Hi there.
Would like to have your impressions and/or experience so far, in using the gas mixture with ETHANOL <form of alcohol generally a sugar cane, corn, beats, derivative, mixed with gasoline>. This has become a trend worldwide and difference may be in proportions. In Panama (Central America) is what you would call E5, as opposed to E10 and E15 I have read there are in other countries (a ratio of 5, 10 or 15 percent ETHANOL per gallon of gas). There is a general resistance to this imposition as to impact in automotives that may have no provisions to function with this fuel, if any. Mayor concerns are now with small engines (water pressure machines, generators, etc.) and why not: MOTORCYCLES, let alone our V's, for one. Some have said not to allow the tank to reach below a quart of its capacity, given Ethanol tends to produce high condensation, therefore water formation into the tank and a pathway to hoses and carburators, etc. This combination evaporates more rapidly, therefore mileage is affected. I am not an expert at all on the subject but wish to sense your concerns, and I may have lost the Forums bringing up this topic.
McGyver is offline
post #2 of 25 (permalink) Old 09-16-2013, 06:18 AM
My bike runs great with or without it on highest octane. Found a station without it and that's the one I try to go to all the time.
Also its best not to use jet cleaner in the fuel.
post #3 of 25 (permalink) Old 09-16-2013, 06:54 AM
genehil's Avatar
I run regular (87 octane) E10 gasoline all the time without any problems. I average between 48 and 52 miles per gallon. I run the same stuff in my truck, riding lawn mower, push mower, edger, generator, string trimmer, etc..
GeneHil - Mount Dora, FL
2011 Kawasaki Versys
genehil is offline
post #4 of 25 (permalink) Old 09-16-2013, 08:18 AM
Haven't had problems yet with E10 (it's all that's available here). I have been using treatment in it year-round. Either Stabil marine or Startron enzyme treatment.
HondaGalToo is offline
post #5 of 25 (permalink) Old 09-16-2013, 08:33 AM
+1.
But a couple of years ago, when real (regular) gas was available here along side E10, I did find that I got better mpg with real gasoline. That is because gasoline contains more Btu/gallon than ethanol.
I've read that E15 is not good for motorcycles, small engines, or older cars.
trialsguy is offline
post #6 of 25 (permalink) Old 09-16-2013, 11:52 AM
As long as you're regularly going through the gas, and not letting it sit for a month+, it should be fine. Even with a stabilizer, gas that's been sitting for a few months makes my mower and weedwhacker run a bit rough.
TwoTacoCombo is offline
post #7 of 25 (permalink) Old 09-16-2013, 12:03 PM
When I put my V away for the winter, I fill the tank with 100% gasoline (no E10), and some gas stabizer, then run it to get the stabilizer into the injectors. The only hitch - is I have to ride to the next county to get it, and it is only available in Premium. But that way there is little or no ethanol sitting in the tank or fuel system, to cause moisture or corrosion over the winter.
post #8 of 25 (permalink) Old 09-16-2013, 12:13 PM
Retro Rocketeer's Avatar
I handle the majority of servicing and major repairs for our states training bikes. Ethanol damage and corrosion problems are real. Attached is a picture of a float bowl from a TW200. This bike got used about 3 weekends in one month. Not what you would call commuter use by any means, but more than some bikes get used recreationally. Those yellow/orange booger blobs you see are the biomass created from phase separation. Those are pretty large. You can bet they'll clog up small passages, and they do. Look closer. The float bowl also appears to have a lot of speckling. That is etched aluminum. The ethanol eats away at the soft metal. Your fuel system out of the tank is aluminum and brass. When I clean away those blobs, it will leave behind similar pitting/etching.
Those blobs are not always present when I get a "bike won't run" service call. Sometimes I pull the carb apart and it looks clean to the inexperienced eye. I've learned to look for the speckling of the metal. I pull the pilot jet and sure enough, can't see light through it. Its plugged by debris created from the etching of its own metal. I've had to un-obstruct same bikes twice in just four weeks of use.
Non-ethanol stations are not conveniently located around our training areas for our instructors to use real gas. We have been using Star-tron, Seafoam, and Lucas, whatever is easy for our instructors to source in their areas. We've cut down on these fuel problems by about half now, though problems still arise.
Its funny. When you read about this stuff in AMA and the newspapers, they say they are talking to congress and agencies about "alleged ethanol damage", and I get to clean all this "alleged" for the state and other customers.
More and more bike shops will not guarantee a carb clean for more than a month now.
My recommend? Use non-ethanol when you can. If you are using your engine daily, like your commuter car, its less of an issue, as there's less time for phase separation. The corrosion is still gradually happening though. I use Lucas in my Yukon and Subaru every 3rd fill up, though is B.S. I should need to. Eliminate the ethanol so we don't have to use even more money to increase the true price per gallon.
Retro Rocketeer is offline
post #9 of 25 (permalink) Old 09-16-2013, 02:20 PM
Originally Posted by trialsguy View Post
...I've read that E15 is not good for motorcycles, small engines, or older cars.
Me TOO!
post #10 of 25 (permalink) Old 09-16-2013, 03:48 PM
Tigerpawed's Avatar
Here's the American Motorcyclist Association's "E15 and Motorcycles Q&A": http://www.americanmotorcyclist.com/..._Q_A.sflb.ashx
and their current issues "action" page should you wish you inform your elected representatives of your opinion: http://capwiz.com/amacycle/home/
Tigerpawed is offline
post #11 of 25 (permalink) Old 09-16-2013, 05:07 PM Thread Starter
I appreciate the feedback from you all. I think that one and each has a lecturing experience and force to readjust maintenance schemes and measures to be taken to prevent damage or malfunction to our investments. I just have a final concern: I want to ask the architect of this ETHANOL idea, in any event, where and what he fills up... because as gathered, some have no choice. Eligibility should be optional. Cheers
McGyver is offline
post #12 of 25 (permalink) Old 09-16-2013, 05:23 PM
There aren't too many choices when it comes to buying gas in small town central Maine but, fortunately, one of the marinas on Moosehead Lake sells non-E gas at it's boat fuel dock and that's what I fill the bike's tank with before it goes into storage for the winter - along with a fuel stabilizer.
I wouldn't put E15 in any of my vehicles any more than I would fill them with corn syrup.
post #13 of 25 (permalink) Old 09-16-2013, 05:28 PM
invader is online now
post #14 of 25 (permalink) Old 09-16-2013, 06:43 PM
DaveC's Avatar
So, would Seafoam also work?
http://seafoamsales.com/sea-foam-with-ethanol-fuels/
Dave C
2008 Versys (Red)
DaveC is offline
post #15 of 25 (permalink) Old 09-16-2013, 06:54 PM
Seafoam Motor Treatment is just a cleaner, and is not specifically formulated to protect againt the harmful effects of ethanol in gasoline... They are only stating that it can be used with ethanol fuel.
post #16 of 25 (permalink) Old 09-16-2013, 06:55 PM
Tigerpawed's Avatar
Five pure gas stations in all of California, all at the extreme North end of the state. Welcome to paradise.
post #17 of 25 (permalink) Old 09-16-2013, 08:24 PM
I was pleasantly surprised to find several gas stations in the Florence SC area that sell ethanol-free gas. Since that discovery, I have used pure gasoline for the last several fill-ups. I figure it can only be good in the long run especially since I'm not using my V for daily commuting.
Interestingly, I took a recent trip up to Richmond VA and there were no stations listed there that sell pure gas. I guess it helps if you live relatively close to lakes or waterfront where there is a large boating community.
2012 Kawasaki Versys
MichelinMan67 is offline
post #18 of 25 (permalink) Old 09-16-2013, 08:54 PM
There have been countries using this for very long. Brazil is a pioneer using alcohol, I remember in the 80s if you took a car to Brazil that wasn't prepared for their cocktail you had to use many additives to avoid the fuel to destroy the engine.
I don't like ethanol and much less when corn is subsidized by the government.
I believe it ought to be an option and not a mandate..
I can get non ethanol fuel but mid grade only, and if I could chose I would get pure gas but in FL ethanol is everywhere.
Alcohol is hygroscopic it will absorb water, also it will separate from the gas and ruin the engine and rubbers in older vehicles. Unless you use your vehicle daily (like your commute vehicle)
I don't know why the US went for Ethanol instead of CNG. That is cheaper, cleaner and leaves corn to feed people.
Sent from Motorcycle.com App
Murquiza is offline
post #19 of 25 (permalink) Old 09-17-2013, 04:16 AM
I won't use ethanol fuel for the reasons offered above. My personal opinion.
post #20 of 25 (permalink) Old 09-17-2013, 11:40 AM
No problems with ethanol in either the Versys (regular) or the car (premium).
TR Versys is offline
