Wife says brake light stays on after stop or comes on over bumpy roads. Anyone have a faulty switch? Lowered the pedal for new footpeg lowering kit but that should not have affected the switch? Problem came about 75 miles into todays ride. Ideas? thanx.
I had this happen on my bike. I took a pair of needle-nose pliers and very slightly stretched the spring which activates the brake light. It's hard to see but you can just catch a glimpse of it from the back of the bike, so no need to disassemble the footpeg bracket again.
I had a similar problem with my 08 V. I went to my dealer since the bike is still under warranty and they found that the micro switch was faulty so they changed it, no cost at all.
Hope your plastic switch adjustment nut turns easier than mine.
My manual blithely advised me to unplug the switch and turn the nut. Several ensuing wasted hours epitomized why I try never to read manuals. In the first place, to unplug the switch I would need hands the size of an eight year old, with two wrists apiece and the iron grip of a mason. SOP to anyone who has maintained a Japanese bike. Second place, the damn plastic nut was thoroughly frozen to the plastic switch body. After so many failed strategies, I had to remove the foot peg bracket to reach behind where I could break the nut free and spray silicone lube on the business. On the plus side, the socket head screws they used at the factory, made from recycled cap guns for robust strength, were already chewed up at the heads by the assembly process, so that I didn't have to feel like the dummy who chewed them up. They came that way, so that was good. On the minus side, the only way to test adjustment is to reassemble. Switch still stuck on.
Tomorrow, I'm gonna find my bent needle nose and stretch the spring... done trying to do it the right way.
Any "simple" project which winds up requiring an EZ Out is not my favorite project.
Related Threads
Kawasaki Versys Forum
507.6K posts
81.9K members
Since 2008
