What do I need to g et my back wheel off the ground? - Kawasaki Versys Forum
post #1 of 24 (permalink) Old 06-04-2009, 04:37 PM Thread Starter
tenover's Avatar
I just need to be able to lift the back wheel up to do chain maintenace. Looks like people have spools or sliders attached somewhere back there and use a little lift to do this? Any idea where I can get the spools cheap?
tenover is offline
post #2 of 24 (permalink) Old 06-04-2009, 04:42 PM
You can get spools from almost every sportbike supply house. You need the 10mm ones. There are lots of rear stands. The cheapest is probably the one Harbor Freight sells: http://www.harborfreight.com/cpi/cta...emnumber=99701
Spools here: http://www.harborfreight.com/cpi/cta...emnumber=66926
I use a Woodcraft stand, but there are others.
09 Versys
00 KLR
USN 1959-65
ttpete is offline
post #3 of 24 (permalink) Old 06-04-2009, 04:58 PM Thread Starter
tenover's Avatar
tenover is offline
post #4 of 24 (permalink) Old 06-04-2009, 06:09 PM
Dave E's Avatar
Yes the 10 MM will work for the spools.
Regards,
Dave
2009 Versys (Metallic Moon dust Gray) Speedy lowering pegs, Speedy Kick stand pad, Speedy Mirror extensions, Vario Windshield, Oxford heated grips and SW-Motech Engine Guards.
2008 KLR (Red) - Sold
Dave E is offline
post #5 of 24 (permalink) Old 06-04-2009, 06:23 PM
Barter a friend a cold beer to hold it up on the sidestand while you do your business back there. It's not really worth a good beer, though.
neil_asheville is offline
post #6 of 24 (permalink) Old 06-05-2009, 09:36 AM
I do it myself. Just engage the stand on the left side and slowly push down while guiding the right spool, and when they're both engaged, raise the bike.
09 Versys
00 KLR
USN 1959-65
ttpete is offline
post #7 of 24 (permalink) Old 06-05-2009, 09:46 AM
potus2012's Avatar
Originally Posted by tenover View Post
That's a good deal on American made spools. Wish I'd seen it before I bought similar Lockhart Phillips spools. BTW, I think they're too short to protect much in a slide, but should do a fine job as lift points.
potus2012 is offline
post #8 of 24 (permalink) Old 06-05-2009, 10:02 AM
cuff's Avatar
All you need is a stick. Of course I have a fancy painted black one with a yellow zip tie, but it's not required to get the rear off the ground. Any old stick will do.
edit: Forgot to add the picture.
IBA# 38547
cuff is offline
post #9 of 24 (permalink) Old 06-05-2009, 01:00 PM
gti20vturbo's Avatar
Just put the bike on its side stand and use a good floor jack under the muffler and jack it up enough to work on your chain. Done it that way for years on bikes without centerstands. The bike will balance on the floor jack, side stand and front wheel just fine.
ST1300, Versys, SV650S
gti20vturbo is offline
post #10 of 24 (permalink) Old 06-09-2009, 07:59 PM
[QUOTE=cuff;39097]All you need is a stick. Of course I have a fancy painted black one with a yellow zip tie, but it's not required to get the rear off the ground. Any old stick will do.
+1 on the stick.
They sell a fancy one for about $50 (US), but any stick works. I put the bike on the side stand, turn and lock my front wheel, use some rope to tie the front brake lever closed (brake on), then lift the bike up onto the side stand and put the stick under the bike (like in photo). Takes all of 1 minute, works great, costs zip. If I need the bike more upright I'll put a jack stand under the right foot peg and use a pump jack under the left one to pick the bike up to where I want it.
Docteric is offline
post #11 of 24 (permalink) Old 06-09-2009, 08:49 PM
xprovince's Avatar
[QUOTE=Docteric;39703]
+1 on the stick.
great ideas !!!!!
V
xprovince is offline
post #12 of 24 (permalink) Old 06-10-2009, 09:53 AM
Wait 'til the bike falls over from using makeshift methods. It'll cost more than a proper stand would have.
09 Versys
00 KLR
USN 1959-65
ttpete is offline
post #13 of 24 (permalink) Old 06-10-2009, 01:21 PM
maddjack's Avatar
On the road I use a quickstand and at home I use a pitbull multistand,both require spools(10mm )
heres the quickstand site
http://www.motorcycleradar.com/quick_stand.htm
AMA EAA STN
maddjack is offline
post #14 of 24 (permalink) Old 06-10-2009, 01:45 PM
bbarend's Avatar
Get going about 15 mph and grab a handful of front brake. That should get it off the ground.
bbarend is offline
post #15 of 24 (permalink) Old 06-10-2009, 04:38 PM
Any pics?? You know what they say, no pics, it didn't happen...
By the way, I added spools & use jack stands...
post #16 of 24 (permalink) Old 06-10-2009, 05:08 PM
cuff's Avatar
That's why you measure the stick first. For the shop it's a bike stand. Not really an option on a road trip. If by some chance the bike falls over I'll pick it up and keep on ridin'. Oh wait, been there done that.
btw, the fall wasn't from the stick.
IBA# 38547
cuff is offline
post #17 of 24 (permalink) Old 06-10-2009, 06:53 PM
xprovince's Avatar
get going around 30km and hammer that front brake and hopefully that will get you do your stoppies
V
post #18 of 24 (permalink) Old 06-10-2009, 06:53 PM
xprovince's Avatar
oh stand that what you were meaning
V
post #19 of 24 (permalink) Old 06-15-2009, 10:22 AM
Been doing it that way for 30 years, one hasnít fell over yet.
post #20 of 24 (permalink) Old 06-15-2009, 03:06 PM
Hope your luck holds out. Harbor Freight stands are pretty inexpensive.
09 Versys
00 KLR
USN 1959-65
ttpete is offline
