Fiamm freeway blaster horn - Kawasaki Versys Forum
post #1 of 10 (permalink) Old 09-05-2013, 11:54 AM Thread Starter
To the resident experts or those who did the mod,
Can I install this horn using the stock wiring? or will I fry them? Do I need a relay?
http://www.amazon.com/FIAMM-72112-Freeway-Blaster-Horn/dp/B000DINKPQ/ref=wl_it_dp_o_pC_nS_nC?ie=UTF8&colid=3KIUKO5LOF3CL&coliid=I1IOW747UYTEOL
I installed this in my first bike a Suzuki TU250x with no issues, worked great.
Thanks in advance.
ESE_VERSYS2013 is offline
post #2 of 10 (permalink) Old 09-05-2013, 02:09 PM
Zatx's Avatar
Mine is going strong after a year of use using the stock wiring.
Be aware that your link is to the single horn unit.. you have to have both the high and low horn for it to be loud. The link is just for the low horn. This will sound just like the stock horn and not be any louder.
This will work better for you if you want to stick with stock location and wiring:
http://www.amazon.com/85110-115db-400HZ-500HZ-Sports/dp/B00067BWBI/ref=sr_1_1?s=automotive&ie=UTF8&qid=1378408258&sr=1-1&keywords=PIAA+Horn
If you want really loud and non-stock position and wiring going with this:
http://www.amazon.com/GENUINE-Stebel-Compact-Nautilus-Motorcycles/dp/B00CMX20H4/ref=sr_1_1?s=automotive&ie=UTF8&qid=1378408366&sr=1-1&keywords=stebel+horn
Zatx is offline
post #3 of 10 (permalink) Old 09-06-2013, 08:54 AM
Banned
Would either the high or low note Fiamm horn work in conjunction with the standard horn that is on the Versys??
Has anyone tried this?
IF l was to purchase a Fiamm horn & just run a link wire from the existing horn, would this "fry" the wiring even if I rarely use the horn, & if I do it would be no more than a 2-5 second "blast".....?
Britmick is offline
post #4 of 10 (permalink) Old 09-06-2013, 10:04 AM
Zatx's Avatar
The horn barely draws any power and neither do these types of aftermarket electronic horns. You should be fine. I imagine it would be the same draw as buying the low and high horn from Fiamm. The aftermarket Stebel type horns draw more power because they are actually powering a small compressor.
The part I can't answer is if the sound would be any louder used in conjuction with the stock horn. I'm not sure what mhz the stock one operates at. If I had to guess I would say it isn't any louder.
Zatx is offline
post #5 of 10 (permalink) Old 09-06-2013, 11:25 AM
...IF l was to purchase a Fiamm horn & just run a link wire from the existing horn, would this "fry" the wiring even if I rarely use the horn, & if I do it would be no more than a 2-5 second "blast".....?
When I ran my Stebel thru my Fuzeblock, I initially installed a 5 amp fuse, but a longish horn "blast" blew that fuse, so I changed to a 10 amp (the wiring is either 12 or 14 gauge, so sufficient), which is working fine. IF the Fiamm draws as much as the Stebel, you MIGHT fry the stock wires.
post #6 of 10 (permalink) Old 09-06-2013, 12:33 PM
Lours_Polaire's Avatar
From one of my favorite source of info on motorcycle "stuff"
http://www.webbikeworld.com/t2/horn-...horn-relay.htm
Freeway balster pull 5 amp from each
The thicker your wire, the less resistance to current it will give, hence the less heat it will generate, hence more current to the device
Further more, heat in wire increase the resistence, so it's a catch 22 situation
Better to go ahead and run big wire and use the existing one for signal, using a relay
My 2 cents
LOP
Lours_Polaire is offline
post #7 of 10 (permalink) Old 09-06-2013, 08:25 PM
djg
Buy both low and high, use a relay and heavy wire. You'll sound like a Cadillac.
djg is offline
post #8 of 10 (permalink) Old 09-06-2013, 09:16 PM
I run the Piaa.
http://www.kawasakiversys.com/forums...ad.php?t=18520
See post #23 at the link above.
No probs with stock wiring.
post #9 of 10 (permalink) Old 09-06-2013, 11:47 PM
Banned
Does anyone know if the standard horn is high or low, so l can buy the opposite?????
Britmick is offline
post #10 of 10 (permalink) Old 09-07-2013, 12:45 PM
djg
It's different, the Fiamms are a set, the stock is a standalone. Buy both Fiamms, use a relay and heavy wire, I guarantee you will be satisfied. They are like ten bucks each.
djg is offline
