cheap fork seal driver - Kawasaki Versys Forum
post #1 of 1 (permalink) Old 05-29-2009, 03:56 PM Thread Starter
The other night I was removing my forks (KTM exc 250) bring them in to get the seals replaced (have never changed seals before) before I knew it the forks were apart on the wok bench. In the next step I needed a seal driver and it was much to late to call anyone to see if they had on. After looking in the garage I found a piece of abs pipe which i cut in half and placed around the fork. I used a hose clamp to hold the 2 halves together (abs pipe). It actually worked quite well probably not as good as a seal driver but when it is 2 AM and you are in a bind
buckshotsktm is offline
