Problem with 16 teeth - Kawasaki Versys Forum
post #1 of 13 (permalink) Old 05-26-2009, 07:53 PM Thread Starter
spiderman's Avatar
I just swapped out the front sprocket to the 16 tooth. I was hearing some noise when I backed off the throttle. As you can see from the picture, when there is some slack in the chain I'm getting some interference with the front sprocket guard. I don't remember hearing of this problem from others and I'm wondering if I did something wrong. The chain is properly adjusted. Any ideas?
Jeff in Illinois
07 Bandit
03 KLR
82 Rokon
spiderman is offline
post #2 of 13 (permalink) Old 05-26-2009, 08:13 PM
Dave E's Avatar
You have me wondering now! I think I am going to take a peek at mine when I get a chance.
Regards,
Dave
2009 Versys (Metallic Moon dust Gray) Speedy lowering pegs, Speedy Kick stand pad, Speedy Mirror extensions, Vario Windshield, Oxford heated grips and SW-Motech Engine Guards.
2008 KLR (Red) - Sold
Dave E is offline
post #3 of 13 (permalink) Old 05-26-2009, 08:41 PM
That is a tight fit. The chain rides a bit higher on the sprocket's rubber damper. I guess others just didn't notice, and it eventually wore itself some grooves... I didn't have that problem with a 16T without the damper, but it was noisier from not having a damper. My chain was snagging and wore into the back of the damperless 16T, and it also stretched unevenly from the start. I put my unused 15T back on with a bigger rear sprocket instead and a new chain. It's perfect now.
post #4 of 13 (permalink) Old 05-26-2009, 08:47 PM
LoneRanger's Avatar
My 2 cents
Mine was the same way. It is a VERY TIGHT FIT. Mine did not rub. I had a noise on DECEL during my 3 mile test ride. I came home - put some moly grease on the sprocket (I forgot to put grease on it when I installed it). Then took it out and the decel noise was gone.
LoneRanger is offline
post #5 of 13 (permalink) Old 05-26-2009, 09:33 PM
Chicken Little's Avatar
I am resisting the urge to hit that fin with a hammer and a small old screw driver. Somebody tell me why a few well placed whacks wouldn't fix this problem. Would it break off?
Chicken Little is offline
post #6 of 13 (permalink) Old 05-26-2009, 10:07 PM
Don't think I would wack it but I would go at it with a dremel.
Mark Milanowski is offline
post #7 of 13 (permalink) Old 05-27-2009, 04:39 AM
Yeah, a Dremel would be better. It is made of cast aluminum, and a hammer would break it before it bends.
post #8 of 13 (permalink) Old 05-27-2009, 02:28 PM Thread Starter
spiderman's Avatar
Well, I've ridden a few more miles and the sound is fading away of course. I think I'll just leave it alone and let it wear on it's own. I see no reason to grind off any more than I need to. Then I guess I'll clean out all the filings so it won't wear on the chain. I'm just a little surprised I hadn't heard about this little feature earlier.
I really do like the difference in the gearing. I always thought 1st gear was a little short anyway and this seems about right. Naturally, the difference in top gear is nice too. I think I'll like it.
Jeff in Illinois
07 Bandit
03 KLR
82 Rokon
post #9 of 13 (permalink) Old 05-28-2009, 10:47 AM
Jeff,
I'm sure you noticed too, but there's some rust on your chain. Not good.
post #10 of 13 (permalink) Old 05-28-2009, 11:56 AM
Machog's Avatar
alvis and myself added a 16tooth rubber backed sprocket about a year ago and probably both have well over 10k miles on it by now.
Makes the speedo nuts on, but the odometer reads about 6% less, which is no problem. I wouldn't be without it now. Lowering the revs when cruising on the freeway smoothed out the ride considerabley.
We didn't do any modifications to the front casing, it was tight but certainly didn't touch anywhere.
Machog
Machog is offline
post #11 of 13 (permalink) Old 05-28-2009, 04:28 PM Thread Starter
spiderman's Avatar
Jeff,
Yeah I caught that too Ed. Actually, I hadn't noticed it til I took that photo. I've been using that teflon based chain lube from Dupont - the kind that doesn't foam. I must admit that it doesn't build up and has kept the chain pretty clean. But apparently it's not as good at corrosion protection.
Jeff in Illinois
07 Bandit
03 KLR
82 Rokon
post #12 of 13 (permalink) Old 05-28-2009, 09:50 PM
Well, it's not the lube, or it is but not that way It's how you lube and clean the chain. One of the downfalls of this clear lube is that the chain looks clean, although it's not. I am cleaning the chain far more often now, I'd say every 3,000km or so, and then lube it with the Dupont sprayed on a rag. After that it's just regular lubing. No more rust for me.
I rather do this than have oil chain everywhere, but each to its own...
allriding is offline
post #13 of 13 (permalink) Old 05-29-2009, 06:52 PM
RPrice's Avatar
Spiderman,
I've never checked to see if my 16 tooth (not rubber dampened) front sprocket is rubbing! However, when installed, it looked good. There was an increase in noise afterwards, but after about 3k miles, it has greatly subsided (or maybe I'm even more deaf than I was).
I'd better check to see if mine rubs!
regards, Bob
RPrice is offline
