thread size of fairing screws - Kawasaki Versys Forum
post #1 of 9 (permalink) Old 08-14-2013, 11:31 PM Thread Starter
One of the screw holes that holds on the front side fairing is stripped so I have to buy a tap to rethread it. Does anyone now the thread type for these?
versys_rider is offline
post #2 of 9 (permalink) Old 08-15-2013, 02:08 AM
M6 X 1.0mm, 16mm socket bolt thread length.
Don't you have to tap it larger?
post #3 of 9 (permalink) Old 08-15-2013, 02:54 AM
Depending on depth you may squeak in with a helicoil.
kiwitourer is offline
post #4 of 9 (permalink) Old 08-15-2013, 01:08 PM
I'm pretty sure it's a 6mm. I always use blue Loctite on those, so "every-now-and-then" I 'chase' the threads on the bolts and the holes. The only 5mm ones in that area (as I remember) are the ones that hold those little black plastic pieces that go from around the front 6" of the seat, forward to the tank.
(I bought a budget set of taps and dies from Harbor-Freight just for thread clean-ups.)
post #5 of 9 (permalink) Old 08-18-2013, 02:07 PM
My Canadian taps and dies are Mastercraft, from Canadian Tire.
They're all M5 X 0.8mm.
I just went out, removed a fairing screw, then turned it into the correct die, and took pics of each step, including w/ the correct tap.
They ARE 6mm x 1.0 pitch. (MAYBE the ones on '07s are 5mm, but DEFINITELY NOT those on '08s or '09s.)
ID:	29842   Click image for larger version
ID:	29850   Click image for larger version
ID:	29858   Click image for larger version
post #6 of 9 (permalink) Old 08-18-2013, 04:07 PM
michael95453's Avatar
fasteddie is right, although the OP didn't specify which generation fairing.
michael95453 is offline
post #7 of 9 (permalink) Old 08-19-2013, 11:15 PM
You tapered the end of your screw? I got the measurement from Kawasaki parts fiche for a 2008... I'll measure mine with my Mastercraft tap and die set.
post #8 of 9 (permalink) Old 08-21-2013, 01:53 AM
Mine are also M6 X 1.0mm... Kawasaki parrts listing does show the correct length of 16mm.
post #9 of 9 (permalink) Old 08-21-2013, 11:47 AM
You tapered the end of your screw?...
Nope - that's how they came on BOTH the '08 and '09.
