Impact Wrench Help! - Kawasaki Versys Forum
post #1 of 8 (permalink) Old 05-19-2009, 05:32 PM Thread Starter
Machog's Avatar
Impact Wrench Help!
I have a 1/2" air impact wrench (from Harborfreight). Its rated at 250ft lbs and requires [email protected], which my compressor has. With me so far?
Thought I'd try it out on the lug nuts on my Ridgeline (rated at 80ft lbs). I knew they would probably be over-torqued.
Wrench made zero impact (pun?) on them. So, jumped on a breaker bar to take them off, re-set them to 80ft lbs with my torque wrench-but still wrench won't undo them.
It says not to set pressure regulator above 90psi.
Wrench has 4 settings with a thumb screw underneath, 1 to 4, I've got it on 4 and yes it is running anti-clockwise.
Any help or suggestions welcome.
Machog
Machog is offline
post #2 of 8 (permalink) Old 05-19-2009, 07:01 PM
Are you using an extension on the socket? Sometimes that will insert enough slack so as to defeat the impact mechanism. I've got a similar 1/2 inch and it'll take off anything I throw at it, so my large trucks wheel changes with it all the time on #4.
Oh, and my compressor is always maxed out on PSI around 140-150 unless I'm doing woodworking.
Starbucker is offline
post #3 of 8 (permalink) Old 05-19-2009, 08:35 PM
This reply is really no help except to say when I bought my impact wrench I did a lot of reading on forums on the same subject. So many inputs were about their well rated for the task impact wrenches not doing the job.
I have the HF Earthquake with a compressor that only does about half of the required SFM at 90 psi, yet when I crank the psi to about 100, that wrench will easily take off the back axle nut and even the front sprocket nut that I COULD NOT get off with a long breaker bar.
Plus, every time I use my Earthquake, I put a drop of air tool oil in the air hole before using. Not using oil over time will reduce the motor torque.
atgatt is offline
post #4 of 8 (permalink) Old 05-19-2009, 09:59 PM
charlesleblanc's Avatar
Unfortunately my Air impact and my compressor are in storage right now but I experienced the same problem last year.
A friend told me that it is probably because the air impact gun is starved for oil, he recommends to put pneumatic oil in the impact gun and it should be able to get to the rated torque again.
UNTESTED
Since my air impact gun is in storage I can't test it but this friends of mine seems trustworthy... trustworthy enough to ride my V (I got his SRAD 750 in return)
Charles Leblanc
2007 Versys
Givi Windshield and side case
Montreal, Quebec, Canada
charlesleblanc is offline
post #5 of 8 (permalink) Old 05-19-2009, 11:00 PM
A air impact wrench should be oiled regularly.
IMHO, for tightening bolts to specs, a manual torque wrench is the way to go.
Overtighting just causes a lot of problems.
Thanks.
post #6 of 8 (permalink) Old 05-20-2009, 12:16 PM Thread Starter
Machog's Avatar
I've got an auto oiler on the compressor, but I'll turn it up-tx for the ideas, maybe the wrench is just too wimpy?
My compressor limits out at 120, but gun says to use no more than 90, but going to turn that up as well.
Machog
Machog is offline
post #7 of 8 (permalink) Old 05-20-2009, 12:27 PM
Nobody runs 90 psi for shop air. 125 is about the minimum. No regulator in line. You also need a 3/8" hose with minimum length. Long undersize hoses will restrict airflow.
09 Versys
00 KLR
USN 1959-65
ttpete is offline
post #8 of 8 (permalink) Old 05-22-2009, 09:26 AM
dallasdon's Avatar
I agree. I always run 100psi + when running my impact. I also have a 3/4" impact for the ornarary jobs. Just drop a few drops of oil in your gun every time your use it.
'09 Versys -Green
TET'68 Survivor
dallasdon is offline
