Waste of money or good idea - Kawasaki Versys Forum
post #1 of 18 (permalink) Old 08-08-2013, 08:47 AM Thread Starter
The Versys being a tall bike, I've noticed the effect of sloshing fuel in the tank, particularly sideways sloshing at a stand still. Has anyone tried fuel tank foam? Does it make a difference? Could this interfere with the fuel level float attached to the fuel pump?
Basically it's porous foam you put in a tank or fuel cell to act as a fuel baffle and prevent sloshing. Claims to only reduce fuel capacity by ~3%.
It's $57 on the Sport Bike Track Gear site but $8 for a block you can cut up on Ebay.
Good idea or waste of money?
http://stores.sportbiketrackgear.com...l.bok?no=13217
http://www.ebay.com/itm/Fuel-Cell-Sa...-/390460813795
post #2 of 18 (permalink) Old 08-08-2013, 09:02 AM
The pupose of it is to not have the gas sliding left to right in twisties and changing the center of gravity?
If that is the job I think its a waste personally.
08' Versys
HAWKSHOT99 is offline
post #3 of 18 (permalink) Old 08-08-2013, 09:08 AM
The foam blocks also hold gasoline in like a sponge, thus reducing your fuel capacity... Fuel sloshing in the Versys has never bothered or concerned me at all anyway.
post #4 of 18 (permalink) Old 08-08-2013, 09:43 AM
+1 with invader. Just don't even notice it anymore!
post #5 of 18 (permalink) Old 08-08-2013, 10:42 AM Thread Starter
Looking at the fuel level pickup I think foam blocks would interfere. As I understand the foam is a type that is completely porous so does not hold the fuel like a sponge.
post #6 of 18 (permalink) Old 08-08-2013, 11:45 AM
RRKVERSYS's Avatar
Waste of money IMO.
RRKVERSYS is offline
post #7 of 18 (permalink) Old 08-08-2013, 11:54 AM
genehil's Avatar
No go...
GeneHil - Mount Dora, FL
2011 Kawasaki Versys
genehil is offline
post #8 of 18 (permalink) Old 08-08-2013, 12:03 PM
If that is the job I think its a waste personally....
IF that is what you want to stop (fuel sloshing side-to-side while riding) - it WON'T work, because cornering a motorcycles is a 'co-ordinated' turn, unlike cages, trikes and sidecar rigs, which corner in 'yaw', thus sloshing fuel side-to-side, which does NOT happen in a 'co-ordinated' turn.
post #9 of 18 (permalink) Old 08-08-2013, 01:21 PM
He never mentioned turns
post #10 of 18 (permalink) Old 08-08-2013, 02:13 PM
I notice this after a fill up too, but it's just a mild annoyance at stops until you're about a gallon down. The extra weight up top from a full tank affects the handling far more than a little bit of sloshing.
TwoTacoCombo is offline
post #11 of 18 (permalink) Old 08-09-2013, 02:18 PM
Smiley's Avatar
Sloshing?? We are both on the same bike, a V right?
$57 buys a lot of gas.
Smiley is offline
post #12 of 18 (permalink) Old 08-09-2013, 02:59 PM
Never heard of this! Just learned something.
I only notice the slosh with a full tank and at a full stop. I have never felt the slosh underway.
I'd pass.
post #13 of 18 (permalink) Old 08-09-2013, 03:59 PM
+1. Really
Also I recall reading a magazine test of tank foam. It reduced tank capacity more than the product mfg claimed it would.
trialsguy is offline
post #14 of 18 (permalink) Old 08-09-2013, 05:05 PM
anders55's Avatar
I know and have sensed what you are talking about. Only at stand still, though. Is this "sloshing" really a problem? For whom and when?
Waste of money I'd say....
anders55 is offline
post #15 of 18 (permalink) Old 08-10-2013, 10:19 PM
andrewhtf's Avatar
Slight sloshing at full tank, yes, but it never bothered me anyway. Pegs scraping all the way yo.
Current : Maroon 2011.
Up next :
andrewhtf is offline
post #16 of 18 (permalink) Old 08-10-2013, 11:29 PM
Nothing to worry about. dont lock such thoughts in your mind and waste your money.
post #17 of 18 (permalink) Old 08-14-2013, 02:45 PM
It helps on a race bike, not worth it on a street bike. We're not going from 150 to 50 in as short a time as possible. It's not as much a side to side issue as it is a back to front weight transfer.
Newsshooter is offline
post #18 of 18 (permalink) Old 08-14-2013, 03:05 PM
Lion's Avatar
I've noticed the effect of sloshing fuel in the tank only when is full but not as strong. I do not see necessary.
The gray-haired bikers do not get to that age of pure luck
Lion is offline
