Finally got her back! - Kawasaki Versys Forum
post #1 of 7 (permalink) Old 05-02-2009, 09:08 AM Thread Starter
Well finally picked my 09 V up from the dealer after two visits. They say the fuel pump was running but not to capacity so they replaced it. Runs like a top now! Now I get that whinning noise from the fuel pump which I never had before but atleast I know its working.
Dr.Das is offline
post #2 of 7 (permalink) Old 05-02-2009, 09:57 AM
Good to hear your V is home.
That whinning sound just tell us the V's awake. Actually it's a good thing so at least we normal folks can figure out what/if anything is wrong.
Cheers
post #3 of 7 (permalink) Old 05-02-2009, 04:27 PM
Yep!! good info! & glad you got 'er back & can enjoy riding it again!!
post #4 of 7 (permalink) Old 05-02-2009, 05:21 PM
My fuel pump must be working but I don't notice a whining sound.
There should be a section in the maintenance book with recordings called "Good sounds and bad sounds".
atgatt is offline
post #5 of 7 (permalink) Old 05-02-2009, 09:17 PM Thread Starter
LOL! You are right Atgatt. At first I heard all kinds of unfamiliar noises when I bought my V but after some research have found out they are all normal. ie buzzing, whistling. There should be a section for "you might hear it, but might not, but it's okay if you do".
Dr.Das is offline
post #6 of 7 (permalink) Old 05-03-2009, 06:41 PM
erxray62's Avatar
P wonder if that is the sound i am hearing? Sometimes when i go into the garage my v starts making noise like the fuel pump is coming on and then it goes off. Is this normal?
erxray62 is offline
post #7 of 7 (permalink) Old 05-03-2009, 07:47 PM
brothercannon's Avatar
I hear a high pitched noise some times from my when it is just sitting there not running. I think it is a check valve releasing pressure from the gas tank, but that's just my guess. I want to describe the sound but it's much harder to do with just text. It would be nice to record it but it just happens randomly.
brothercannon is offline
