Vista or Nep Cruise modification needed? - Kawasaki Versys Forum
post #1 of 6 (permalink) Old 04-28-2009, 10:15 PM Thread Starter
mbf
I am looking at putting a NEP or Vista Cruise on my 2009. Has anybody done this and if so, did they install easily as packaged or did you have to make modifications?
mbf is offline
post #2 of 6 (permalink) Old 04-28-2009, 10:19 PM
Chicken Little's Avatar
I did modify the standard vista cruise. I had to dremel the interior portion to fit over the ridge on the throttle tube, and I stuck a small screw into the starter button housing to hold it when engaged. Took me maybe a half and hour, and was well worth it.
Chicken Little is offline
post #3 of 6 (permalink) Old 04-28-2009, 11:25 PM
You'll need to modify the throttle lock, as CL said, the throttle tube has a ridge that creates too much friction with the TL. I went the other way and filed the throttle tube. See this thread.
Gustavo
Gustavo is offline
post #4 of 6 (permalink) Old 04-29-2009, 08:00 AM
Gustavo-
WHY,WHY, WHY did I not file the throttle tube? What is wrong with me, why do I make things so hard?
I'm an idiot.
post #5 of 6 (permalink) Old 04-29-2009, 11:25 AM
Machog's Avatar
This was my solution, all it needs is a longer bolt on the top of the brake reservoir mount and a 1/2" spacer.
No other cutting trimming or alterations.
Machog
Machog is offline
post #6 of 6 (permalink) Old 04-30-2009, 11:19 AM
I did mine the same as Machog did (AFTER I read his post, months ago!).
Works GREAT!
