installing italian horn - Kawasaki Versys Forum
post #1 of 15 (permalink) Old 06-28-2013, 12:41 AM Thread Starter
Purificator's Avatar
Hello guys,
I bought this item:
http://www.ebay.com/itm/390360151327...witem=&vxp=mtr
when I installed it as per the guide and push the horn button, it drains so much power than the lighting of the dashbord and the lamps starts shaking and yet the horn sound is weak as if it does not receive enough power...
the description of the item says it is suitable for both 12v and 24v...I contacted the seller and yet I'm waiting for his response...meanwhile I don't want to think that I paid 53 USD for nothing :S
my battery is still almost new and tested the voltage which is within the normal level.
am I missing something??
Thanks!
Purificator is offline
post #2 of 15 (permalink) Old 06-28-2013, 01:03 AM
Did you use a relay?
post #3 of 15 (permalink) Old 06-28-2013, 01:06 AM Thread Starter
yes it is provided with the horn in the package...but the relay is not meant to increase the power right? (I'm dumb in electricity and without the provided guide I wouldn't have tried it myself...)
post #4 of 15 (permalink) Old 06-28-2013, 01:28 AM
The relay's purpose is to isolate the horn's high current draw from your horn button switch.
I see the Ebay seller is very hard to deal with... The horn is probably too big and/or of poor quality.
post #5 of 15 (permalink) Old 06-28-2013, 01:36 AM Thread Starter
I see...so if the current is not isolated from the button switch this will cause the interruption in the sound...probably I should take it to an electrician to install it again and see...
the horn is substantially big...and the video test made it look compact and I loved the high tone...but I thought since it is 12v it should be ok....I will give it a second try through my local shop..
post #6 of 15 (permalink) Old 06-28-2013, 01:42 AM
If the horn is not isolated from the button switch with a relay, you can burn out your horn switch, which would result in no power at all to the horn... You did wire it up as directed with the supplied relay.
post #7 of 15 (permalink) Old 06-28-2013, 02:16 AM Thread Starter
so what could be the cause? I saw some friends having DVD players on their motorcycles! for a horn my versys already shakes because it is two powerful??
post #8 of 15 (permalink) Old 06-28-2013, 02:44 AM
Have you removed the stock horn? Is your replacement relay wired to horn button lead, or to the stock relayed horn power source (where stock horn was hooked up)?
http://s198.photobucket.com/user/kcb...36156098528589
post #9 of 15 (permalink) Old 06-28-2013, 02:53 AM Thread Starter
I removed the stock horn and used its wires through the relay...but the installation seems a bit different from the one you attached....let me get the set up again and take shots for you ...
post #10 of 15 (permalink) Old 06-28-2013, 03:01 AM
Yeah I saw your instructions calling for using the stock relay to power their supplied relay, which is fine... The Euroblast horn just has too much current draw, and/or is a piece of crap, unfortunately.
post #11 of 15 (permalink) Old 06-28-2013, 03:05 AM Thread Starter
this is it: it has 4 different set up including whether to keep the original horn or not...
post #12 of 15 (permalink) Old 06-28-2013, 03:09 AM
The 3 "X" symbols in the diagrams show how stock horn is disconnected (cut off) from the circuit, as you did by removing stock horn.
post #13 of 15 (permalink) Old 06-28-2013, 07:38 AM
Your battery and horn connections are good and tight?
post #14 of 15 (permalink) Old 06-28-2013, 08:16 AM Thread Starter
yes they were...but I would take it to an electrician as I might have done something wrong...just to double check...
post #15 of 15 (permalink) Old 06-28-2013, 02:23 PM
You need to wire directly from the relay teminal 30 to the + battery terminal with 12 ga. wire, then with the same wire from terminal 87 to the horn. Your original horn wires go to terminals 85 and 86.
Use a 20 amp fuse in the line from the battery to the relay.
09 Versys
00 KLR
USN 1959-65
ttpete is offline
