cam chain adjust? - Kawasaki Versys Forum
post #1 of 4 (permalink) Old 04-15-2009, 07:46 PM Thread Starter
cam chain adjust?
I am hearing a little noise from the engine that I think may be a slightly loose cam chain.
I am not sure if this thing even has a cam chain, but it looks like on the right side of the engine on the back of the cylinder there is an adjustment.
If that is an adjustment, does anyone know the procedure for adjusting it??
I don't have a manual, and don't feel comfortable asking the dealer how to do work that he is in the business of selling.
Thanks August.
2008 Concours
2008 Versys
Restored 69 Honda Trail 90
Whizzer motorbike
august is offline
post #2 of 4 (permalink) Old 04-15-2009, 08:12 PM
scooter650's Avatar
it's self adjusting , unless you have a million miles on it or ran it dry of oil, I don't think that's what you're hearing , What you see is the spring tension release for loosening it to remove the cams for the valve shim adjust or cylinder removal.....
from the service manual:
This is a non-return type camshaft chain tensioner.
The push rod does not return to its original position
once it moves out to take up camshaft chain slack.
Observe all the rules listed below:
When removing the tensioner, do not take out the
mounting bolts only halfway. Retightening the
mounting bolts from this position could damage
the tensioner and the camshaft chain. Once the
bolts are loosened, the tensioner must be removed
and reset as described in "Camshaft Chain Tensioner
Installation."
Do not turn over the crankshaft while the tensioner
is removed. This could upset the camshaft chain
timing, and damage the valves.
Remove:
Cap Bolt [A]
Washer [B]
•Remove the spring [A].
•Remove the mounting bolts [A] and take off the camshaft
chain tensioner body.
Camshaft Chain Tensioner Installation
•Replace the O-ring [A] with a new one. •Apply grease to the new O-ring. •Release the stopper [B] and push the push rod [C] into
the tensioner body [D].
•Install the tensioner body so that the stopper [A] faces
upward. •Tighten the tensioner mounting bolts.
Torque - Camshaft Chain Tensioner Mounting Bolts: 9.8
N·m (1.0 kgf·m, 87 in·lb)
•Install:
Spring [A]
Washer [B] •Tighten the cap bolt [C].
Torque - Camshaft Chain Tensioner Cap Bolt: 20 N·m (2.0
kgf·m, 15 ft·lb)
•Turn the crankshaft 2 turns clockwise to allow the tensioner
to expand and recheck the camshaft chain timing.
scooter650 is offline
post #3 of 4 (permalink) Old 04-15-2009, 09:07 PM Thread Starter
Maybe I'm just being too picky. I don't have many miles, maybe 8000 or so.
2008 Concours
2008 Versys
Whizzer motorbike
august is offline
post #4 of 4 (permalink) Old 04-15-2009, 09:20 PM
The automatic cam chain tensioner is a ratchet affair and will tighten as needed. There has been documented proof on the DRZ Thumper Talk forum that the ACCT will prematurely wear the cam chain. So we, or most, put on a manual CCT. The ACCT that I removed from my DRZ has a lot of spring tension and I can understand how it would cause premature wear. On the DRZ it was a cheap and painless installation.
Hipshot is offline
