License light housing melted. Why? - Kawasaki Versys Forum
post #1 of 14 (permalink) Old 04-10-2009, 05:08 PM Thread Starter
Found my license housing melted. When I took out the bulb, it was black and had a big bulge on it. Very strange. I bought a replacement bulb but this time I drilled some holes in the clear plastic on the bottom of the housing for ventilation. Also put dielectric grease on the metal part of the light before putting it in.
My V has about 41,000 miles but I've never seen a bulb burn out like this, have any of you?
I few weeks ago I noticed that my brake light was staying on. I found that the foot brake housing sensor's stem that goes in and out when you hit the foot brake was not releasing fully. I cleaned it and sprayed some WD40 and since then it has been fine.
atgatt is offline
post #2 of 14 (permalink) Old 04-10-2009, 06:51 PM
I haven't had the bulb problem but the same thing was happening with my brake light. I think it was related to my installation of Speedy's footpeg lowering blocks (which requires adjustment of the brake pedal). I took some needle nose plyers and ever so slightly stretched the spring which activates the brake light. All better now.
Mt. Versuvius is offline
post #3 of 14 (permalink) Old 04-10-2009, 07:37 PM
amir_zwara's Avatar
wow, hmm.. if you find out why/how this happened (the meltig issue) let us know... I'd like to aviod such an issue if possible.
amir_zwara is offline
post #4 of 14 (permalink) Old 04-11-2009, 08:52 AM
charlesleblanc's Avatar
I might have an explanation for that:
Sometimes light bulbs filament will short partially, the result is the bulb become brighter and burns out quickly.
You might have seen a 60W lights becoming really bright just before burning out. You might have had something like that, the bulb was running brighter and hotter and burnt out fairly quickly.
I would check the wiring to make sure that the insulation has not melted but simply replacing the bulb would solve the problem.
Charles Leblanc
2007 Versys
Givi Windshield and side case
Montreal, Quebec, Canada
charlesleblanc is offline
post #5 of 14 (permalink) Old 04-11-2009, 09:38 AM Thread Starter
Thanks Charles, that could have been. A brighter light may or may not blow the fuse, I don't know. Obviously, mine didn't blow the fuse.
Why Kawasaki made that small housing so seemingly air tight, I don't know either; it's not as if I am submerging the bike in water up to that light height.
I don't know either if it was the bulb that got brighter causing the housing to melt, or the heat building up inside that overheated the light. How long it has been melting, I don't know either.
Now that I drilled holes in the bottom I can't check if after a long ride if the housing felt very warm or not. Also, I don't know if rain water affected it by blowing in any very small crack.
atgatt is offline
post #6 of 14 (permalink) Old 04-12-2009, 12:21 PM
Your bulb's filament did end up shorting out, creating more heat until it burnt out... An LED (R5W wide) bulb creates virtually no heat, has less current draw and a much longer life, and is shock and vibration resistant.
http://cgi.ebay.com/ebaymotors/2x-21...Q5fAccessories
post #7 of 14 (permalink) Old 04-12-2009, 01:08 PM
This really is freaky. Filament shorting is the only reason I can think of but, by the time that occurs, the filament is so fragile that going over a bump should break it. I can't imagine this happening again. Charles is right - you should make sure there is no conductor damage - but the fuse should be sized to protect the conductor. If the insulation has overheated we should all be dropping down an amp size with the fuse.
charly is offline
post #8 of 14 (permalink) Old 04-12-2009, 09:19 PM Thread Starter
Thanks Invader. I'll see if an Auto Parts store has that light with the correct size in a LED.
It took a decent amount of heat to melt and singe that housing the way it did. The inside looks almost as if it was on fire. Like Charly said, it's amazing the fuse did not blow.
atgatt is offline
post #9 of 14 (permalink) Old 04-12-2009, 11:09 PM
License plate light is wired with the 10 amp tail/brake light fuse. LED brake light draws only 0.3 amps (3.7 W), and an R5W incandescent bulb (stock) draws about 0.42 amp. So I suppose a 3 or 5 amp fuse would work.
It's a pretty tight fit with the smaller R5W bulb (same base as 1156), but the LED version should fit and work well without the removable tin shield/reflector. If you get an R5W LED (1st pic), don't get one with LED's just on top which emits light only in that direction, and not down on license plate... I'd like to try the larger and more available 1156 LED (2nd pic) with 13 brighter flat LED's (10 around).
post #10 of 14 (permalink) Old 04-13-2009, 08:31 AM Thread Starter
Thanks Invader. I just ordered the 1156 from the site you posted. I'll let you all know how it works.
I should write to Kawasaki about this too.
atgatt is offline
post #11 of 14 (permalink) Old 04-14-2009, 10:38 PM
You should be able to push your LED 1156 in the soft rubber around the socket to install it. You could seal up the holes you drilled with clear silicone or something, to keep dirt and moisture out. You can get a new license lamp cover # 14025-1725 to replace your roasted and drilled one for $7.29.
http://partsfinder.onlinemicrofiche....e=13&A=15&B=56
You should, you could... you can!
post #12 of 14 (permalink) Old 05-02-2009, 08:46 AM Thread Starter
Invader, thanks man, the 1156 LED finally came in and it works great.
Before the LED, even after I replaced the regular OEM bulb with another, that back light housing was very warm after each ride even with the holes I drilled in the clear plastic below the housing.
With the 1156 LED, after a ride, I really can't notice any heat, or maybe just so little it is hard to tell. What a difference!
I did have to take out that metal in the back housing and had to space the housing out about 1/8" because the LED is longer. The LED may fit in a unmelted housing, I don't know. To fill the 1/8" gap where the housing butts up to the back light surface, I just wrapped electrical tape around it.
The LED gives plenty of light without the big heat.
atgatt is offline
post #13 of 14 (permalink) Old 05-03-2009, 12:50 AM
Mursili's Avatar
I figured that, after more then 41000 miles in about a year, that you must have been going something like Mach 3+ and the heat from the drag must have caused the light to burn out.
Seriously, though. I figure that someone like atgatt will find many of the more minor issues with the Versys since they will have ridden it so much. I am sorry to hear about your job loss atgatt. I hope things go well for you from here on out!
Mursili is offline
post #14 of 14 (permalink) Old 05-03-2009, 09:11 AM Thread Starter
Mursili, what is weird is at various times for various reasons, I took pictures of the V. At several points in time, I saw that the housing still looked good, but there are a few pics that showed the housing melted even before I realized it. Then when it melted and I realized it, I found that it melted more as time when on. So, I assume in time, we'll hear other similar stories from others.
After rides, does your rear housing feel very warm?
Thanks for the well wishes about the job situation. There's a lot of people in the same boat. I'm thankful to still ride around town and thankful for a lot of things. It's also nice to be home rather on the road so much, but I miss the road trips too. In reality, my perfect world would be staying home more mixed in with occasional long trips.
atgatt is offline
