Proper chain size for 43T rear sprocket - Kawasaki Versys Forum
post #1 of 7 (permalink) Old 06-07-2013, 04:25 PM Thread Starter
Zander's Avatar
I'm going to have a 43T rear sprocket and new chain installed (using to stock front sprocket).
I've read on here where the smaller diameter of the 43T results in a loss of about 3/4 of the chain adjustment.
So, anyone know the proper number of links for use on the 43T?
Zander is offline
post #2 of 7 (permalink) Old 06-07-2013, 05:03 PM
TowerMan's Avatar
Using the stock 114 link chain, the rear wheel moves back by 0.51" (12.8mm) when using a 15/43T sprocket combo.
If you wanted to, remove 2 links (112 links), and the rear wheel will only move forwards by 0.12" (3.1mm).
Above info taken from this web site - www.gearingcommander.com
Also the 15/43T and 112 link chain will also give a better Same Tooth - Same Link wear ratio than stock - See HERE for details.
Richard
at
TowerMan is offline
post #3 of 7 (permalink) Old 06-08-2013, 09:56 AM
scooter650's Avatar
don't bother
don't bother touching it, I ran the stock chain on a 43t with mine, and after 20,000km it's still going strong with lots of adjustment left yet. all the hassle of cutting, riveting etc isn't worth it imo
scooter650 is offline
post #4 of 7 (permalink) Old 06-08-2013, 10:42 AM
Mursili's Avatar
Sprocketcenter.com sent me a 112-pin chain to go with my 43-tooth rear. It keeps the adjustments near the middle. At one time I posted a picture of where on the length of the chain adjustment the 112-pin chain put things, so it is somewhere on this forum.
Mursili is offline
post #5 of 7 (permalink) Old 06-09-2013, 03:21 PM Thread Starter
Zander's Avatar
Thanks guys, I"m ordering a new chain anyway, so a 112 link it will be.
Z
Zander is offline
post #6 of 7 (permalink) Old 06-10-2013, 07:34 AM
Zatx's Avatar
I'm on the stock chain with 43T and no issues... lots of room to adjust if need be, not sure why you would change it.
Zatx is offline
post #7 of 7 (permalink) Old 06-10-2013, 07:21 PM
Mursili's Avatar
The only reason that I changed the length of the chain is that I was replacing the whole set - sprockets and chain. Then it makes a bit of sense that a smaller rear sprocket will work better with a shorter chain. I am certain that the stock chain will also work, but at some point it is actually advantageous to have the shorter chain.
Mursili is offline
