Stalling? - Kawasaki Versys Forum
post #1 of 21 (permalink) Old 04-02-2009, 08:08 PM Thread Starter
MHansen105's Avatar
Stalling?
Guys,
Anyone else having problems with the Versys stalling?
Several times now my bike has stalled after I let it warm up and start idling at the normal slow speed. It always seems to happen when I've speed up, shifted into second and then pulled the clutch in and slowed down.
The last time it happened was yesterday on my way home from work. The weather was perfect, sunny and in the upper 80's here in South Texas. The bike warmed up normally, I took off from a stop in first, shifted to second then braked and entered a long left turn. She died and while I tried to hit the starter button I must have popped the clutch, the rear locked up and I went down.
I was wearing my gear and am more embarrassed than hurt. Bunged up my left knee a little. I'm really glad I was wearing good boots, as the bike trapped my foot under her. The bike will live to run again, after the shop sorts out the shifter, replaces the left foot pet. The cosmetics will have to wait, but just looking at the scuffed up plastic on the left will remind me to WATCH WHAT YOUR DOING STUPID!
I must say, my wife is being a princess about the whole thing. Her only comment so far has been, ďDonít bother to fix the paint, youíll probably scratch it again anyway!Ē Ya gotta love that!
Ride safe.
Monte
MHansen105 is offline
post #2 of 21 (permalink) Old 04-02-2009, 08:27 PM
Chicken Little's Avatar
Maybe have the shop adjust your clutch while it's in there. Or you can.
Chicken Little is offline
post #3 of 21 (permalink) Old 04-02-2009, 08:32 PM
Mine did that once as i test rode it and came to a stop sign. All we did was set the idle speed up a little as it was low and never had the problem again in 600 miles. You did learn a lessen on not to pop the clutch again while in a turn especially. I can fully understand how that happened and why you are disapointed. Hope the dealer sorts it out and is not a comon problem from what i understand. Does leave a bad taste on a new bike. Hope all goes better and keep us informed on what they think the problem was and if it is resolved.
Yamaha Secca II
1600 Classic-sold
08 Verseys
1986 Corvette
Life is not a practice run. Enjoy each and every day.
Deano is offline
post #4 of 21 (permalink) Old 04-02-2009, 09:07 PM Thread Starter
MHansen105's Avatar
Low Idle
Deano,
I do think the idle was set too low.
I'll definately have the shop look at that.
Chicken Little,
The clutch seemed good. you just can't pop it while your doing 10 MPH leaning into a turn!
Monte
post #5 of 21 (permalink) Old 04-02-2009, 09:43 PM
demuire's Avatar
Send a message via MSN to demuire Send a message via Skype™ to demuire
Mine's done it once or twice, my SV used to do it sometimes too. Generally when running in relatively high RPM and then shutting the throttle down suddenly... It's almost as if the revs drop too much too fast and it doesn't quite stop dropping when it gets to idle speed...
FookStar
2008 Kawasaki Versys (in green!)
Queensland, Australia
demuire is offline
post #6 of 21 (permalink) Old 04-02-2009, 10:02 PM
amir_zwara's Avatar
mine has done this in high elevation... so my guess, like a few others have said is the idle was too low. When your up high there just is not enough oxygen for a low idle speed.
amir_zwara is offline
post #7 of 21 (permalink) Old 04-03-2009, 01:36 AM
Idle speed is easy to adjust. It should be set to 1300 rpm. Throttle bodies vacuum may need to be balanced, which is checked at 1300 rpm idle. Mine was just slightly off. Since adjustment, it idles more smoothly and steadily, with a nice equal thump emited from both cylinders at idle...
post #8 of 21 (permalink) Old 04-03-2009, 08:18 AM
So sorry to hear about this.
Please make sure that dealer does a torture test on your bike after they figure out what to do to be sure the cause is fixed. Having a bike stall in most areas allows you to pull over out of traffic, but as you know, there are a lot of areas that you can't pull over and that is DANGEROUS. Don't tolerate a bike that stalls. You are way too important.
atgatt is offline
post #9 of 21 (permalink) Old 04-03-2009, 02:06 PM
Same thing happened on my prior S2R1k. Gasahol + low idle speed would result in a stalled engine when rolling off throttle at stops. Set the idle to the upper limit and no more issues.
DrJones is offline
post #10 of 21 (permalink) Old 04-03-2009, 07:42 PM Thread Starter
MHansen105's Avatar
Good To Know
demuire, your scenario is exactly what Iíve seen.
invader, I canít believe that my idle has been anywhere near 1300 rpm.
atgatt, the dealerís mechanic and I will have a good session and discussion about this before I accept the bike as ďrepaired.Ē
Thank you all for your validation and kink thoughts.
Iíll keep the site posted with updates on repairs and eventual cosmetic restructuring!
Monte
post #11 of 21 (permalink) Old 04-04-2009, 01:08 AM
Idle adjustment knob is down on the right by your throttle bodies. If your dealer must take care of it for you, have him also adjust the throttle cable slack, clutch cable slack, rear brake pedal height/brake light switch...
post #12 of 21 (permalink) Old 04-04-2009, 01:33 AM
Red Herring's Avatar
If the dealer gave you the bike improperly set up, he might make good with repairs to the body as well? No harm in asking. Glad you are OK.
Red Herring is offline
post #13 of 21 (permalink) Old 04-04-2009, 08:43 AM
redline's Avatar
Hey guys, I know you've heard me harp on this before but.....I've had my idle set as low as 1000 rpm at times, just to see and feel the differences....and I've never had a stalling problem. I feel STRONGLY that the issue may have more to do with ETHANOL than anything else {like a prior poster stated}. The alcohol content of E-10 varies greatly from station to station. Try another brand if it happens again without making any adjustments and see if the problem goes away. This theory kind of makes sense, especially if amir had it happen at higher altitudes {lean}, in which e-10 will amplifiy the problem. IMO.....
redline is offline
post #14 of 21 (permalink) Old 04-08-2009, 08:05 PM Thread Starter
MHansen105's Avatar
Update
Well folks, I just got my V back from the shop today.
Sure enough the idle speed was way down around 800 RPM or so!
Turned her up a few notches to 1,000 RPM and I'll keep an eye on it for awhile.
The dealer did a good job of repair, but no discount.
Ride Safe!
Monte
post #15 of 21 (permalink) Old 04-08-2009, 09:24 PM
redline's Avatar
800 RPM....?!?!?!?! Shoot, I didn't think it would even run at that low an RPM. No wonder.....
BTW....you should keep the idle somwhere closer to the spec, 1300+/- 50 if memory serves me correctly. There are a number of issues THAT A LOW IDLE CAN CAUSE,:
1. Oil pressure, circulation, and deprivation of oil to the top end. Let alone the cooling oil jets under the pistons.
2. Extremely low rpm is very hard on a motor,...even at idle....and the cylinder pulses can cause the working pieces and parts to "hammer" themselves to death.
3. STALLING!!!!!
AND....not to start a war, but I'd be very upset at the Dealer for letting it go that way, at the very least they should offer to fix it for you. It sounds like a blatant "error" on their part.
redline is offline
post #16 of 21 (permalink) Old 04-08-2009, 09:48 PM
Post
Glad to hear your Ok Mhansen and a cager didn't friggin run over you... You might think (and hopefully you will never need them) is a set of crash bars. They saved my V from some serious repair on a drop...Only a scratch on the bars (crash) themselves, best money I've spent...Safe ridin to ya
contractor is offline
post #17 of 21 (permalink) Old 04-08-2009, 09:52 PM
Hmmm... Could've sworn I had posted in this thread...
Anyway, glad you're ok!
I'm curious, was it Universal City Kawasaki?
post #18 of 21 (permalink) Old 04-09-2009, 09:11 PM Thread Starter
MHansen105's Avatar
Update (2)
Redline,
She ran at 800 RPM, but now that Iíve bumped it up I can tell she wasnít happy.
All good points on the possible effects of low idling, I did actually move the idle up to about 1250 (which is the lower end of the range specified in the manual) I may take it up just a bit more, but had no stumbles whatsoever today, and I tried to stall it on purpose!
Iím not so sure I can put all the blame on the dealer. Iíve had the bike for a year now. I did read the manual cover to cover, and STILL never thought to check the idle, even after she stalled a couple of times on me. Thatís not to say that the dealer shouldnít have checked it also, but the final responsibility is always on the operator.
Contractor,
Iíve sure thought about the bars now, and my knee would sure appreciate them!
Bear,
It was indeed Universal City Kawasaki. Theyíre not the friendliest bunch.. The have a good product , and good prices.
They treated me fairly on the repairs.
Thanks to all for all your good wishes.
Monte
post #19 of 21 (permalink) Old 04-09-2009, 10:08 PM
Redline,
Contractor,
Bear,
Monte
Agreed!
post #20 of 21 (permalink) Old 04-09-2009, 11:09 PM
amir_zwara's Avatar
thought of this thread today and checked my idle... mine was also low, near 800or so... but here at this low elevation that didnt stop her from running like a top! either way, i bumped it up to about 1250ish...
