A reminder - empty your swing! - Kawasaki Versys Forum
post #1 of 11 (permalink) Old 06-06-2013, 08:46 AM Thread Starter
anders55's Avatar
I know, as well as you guys, that the rear swing swallows water. Still I had forgotten about this for a while, until today, and emptied 1 deciliter of water...
Don't forget to check the draining hole once in a while!
anders55 is offline
post #2 of 11 (permalink) Old 06-07-2013, 07:39 AM
I am guessing that the hole is on the underside of each swingarm?
ESE_VERSYS2013 is offline
post #3 of 11 (permalink) Old 06-07-2013, 09:14 AM
genehil's Avatar
Here are some more posts about draining your swings...
http://www.kawasakiversys.com/forums...ad.php?t=30130
GeneHil - Mount Dora, FL
2011 Kawasaki Versys
genehil is offline
post #4 of 11 (permalink) Old 06-07-2013, 10:02 AM
Avande's Avatar
Ya thanks for the reminder on that, I have checked mine recently and so far so good.
Lovin every minute of it!
Avande is offline
post #5 of 11 (permalink) Old 06-07-2013, 03:49 PM
Two large holes on the right side, one small hole on the left, just around where the axle is. After tapping a small rock out of that little hole today, I took my drill and made the hole bigger.
post #6 of 11 (permalink) Old 06-08-2013, 06:49 AM
Thanks for the tip. I just checked mine and there was a small stone blocking the nearside (for those of us who ride on the correct side of the road ) swing arm hole. Bloody good aiming from the stone is all I can say.
ElliotReidMD is offline
post #7 of 11 (permalink) Old 06-08-2013, 08:47 AM
genehil's Avatar
Just checked mine and it too had some sort of round looking "stone" that looked all the world like a bead of water preparing to drop. I popped back into the swingarm with a small screwdriver...
I'm the third post here that found a "stone" in the small drain hole on the left side of the bike... or nearside for you guys who drive on the wrong side of the road.
Now I'm thinking that the "stone" is not a "stone" but something that comes from the factory (drop of dried paint?).
And... thanks for the head's up! I found no water but it's now on my periodic maintenance list of things to do...
I'm still wondering about the "stone" thing that several of us have found.
Any thoughts?
genehil is offline
post #8 of 11 (permalink) Old 06-08-2013, 01:18 PM Thread Starter
anders55's Avatar
It's always something blocking that tiny hole, everytime I check.
fasteddiecopeman: Finally someone dared to to do what I have been thinking of doing of since last summer. If you and your bike survive this I will definitely do the same. What size of drill did you use? 6 mm?
anders55 is offline
post #9 of 11 (permalink) Old 06-08-2013, 07:56 PM
dxhFZ's Avatar
Checked mine today, sure enough there was a little stone jammed in there. I pushed it up but no water... Maybe it was acting like a plug? Lol
Bikes:
65cc Benelli Dynamo
Yamaha ttr-125
Kawasaki KX-125
Yamaha Yz426-f (current)
dxhFZ is offline
post #10 of 11 (permalink) Old 06-09-2013, 05:45 PM
Don't remember, but slightly smaller than the holes on the right side.
post #11 of 11 (permalink) Old 06-10-2013, 08:59 PM
andrewhtf's Avatar
washed my bike last nite and remembered to check up on the hole. Sure enough it is plugged up again, with packed mud. Poke it with sharp rod and again the swing took a piss. Would make it a periodic check Everytime i wash the bike.
Current : Maroon 2011.
Up next :
andrewhtf is offline
