Radiator Overflow Tube Dripping - Kawasaki Versys Forum
LinkBack Thread Tools
Old 03-27-2009, 07:54 AM Thread Starter
STeelybeast's Avatar
So I have about 1800 miles on the bike now. The past month or two, I have noticed when I stopped and shut it off, there is a few drops of coolant on the ground when I come back later. I can see it is coming from the overflow tube. I did have the water pump gasket replaced several months ago under warranty as it was leaking. I am not sure if the two are related as I didn't notice it before it was replaced.
The weather is not hot at all, in the 50's and sometimes lower. It's also not after hard riding, just commuting to work and I rarely sit in traffic.
This does not seem normal to me but wondered if others have seen this?
David
STeelybeast is offline
Old 03-27-2009, 08:18 AM
Xo0oM's Avatar
Check to see if there's too much coolant in the reserve tank.
Xo0oM is offline
Old 03-27-2009, 12:32 PM Thread Starter
I checked that and it's just below the full mark. I looked just after I have gotten off from riding and it's still at that mark and not overflowing.
Old 03-30-2009, 08:12 AM
That's what it is supposed to do, release the excess fluid, NO WORRY
sportridertex is offline
Old 03-30-2009, 09:51 AM
Red Herring's Avatar
I would change the coolant. Clean your cap while you are at it.
Mine did this to, new coolant solved the problem.
Red Herring is offline
Old 04-01-2009, 09:34 PM
The guys are Right.
Had a scare too last week.
Had droplets of coolant under the V.
Looked under and found coolant that dripped from the overflow pipe.
Siphoned a bit of the coolant from the coolant reserve container.
Kept it now between Low and High mark.
So far, no more coolant overflow.
Thanks.
