Adding Coolant - Kawasaki Versys Forum
post #1 of 6 (permalink) Old 05-16-2013, 10:14 AM Thread Starter
Adding Coolant
Can I just add coolant if it is running low? Google tells me no, but I never believe him.
Its on the low line, so I want to just purchase some and pour it in. Is there any issues to doing that, or is that normal?
Farkles:
Givi Tall Windscreen, Givi Top Rack and Case, Givi V35 Bags and Mounts, Givi QuickLock Tank Connector+Bag, Oxford Heated Grips, Nuvi 550 w/ Ram Mount, Barkbusters Full Wrap + Storm, Motowerks Flatfoot, Spools and Tank Protector, Bobbed Fender, Grip Puppies, 12v SAE Socket, Packjack, Airhawk 1 (med), Scala Rider G4, Contour Roam2
Next Stop: 44Tooth Sprocket (To be installed)
naudan is offline
post #2 of 6 (permalink) Old 05-16-2013, 10:20 AM
Yes. But its easy enough to just change it. I just did mine 2 weeks ago.
post #3 of 6 (permalink) Old 05-16-2013, 02:04 PM Thread Starter
Thanks -- Is there special motorcycle coolant I should be using? I heard any coolant is fine, but not sure. THe manual doesnt specify.
Farkles:
naudan is offline
post #4 of 6 (permalink) Old 05-16-2013, 04:05 PM
premixed 50/50 distilled
water/ethylene glycol into the radiator.
Heres what i used. http://www.motorcycle-superstore.com...chAutoComplete To fill the radiator and fill the overflow bottle to the full line took about 1.5 bottles
post #5 of 6 (permalink) Old 05-16-2013, 04:17 PM
When you take out the coolant plug to drain it the fluid will come out in a weak stream. When you take off the radiator cap while its draining it will come out in a good steady stream so make sure to watch out that it doesn't shoot over whatever your draining into.
post #6 of 6 (permalink) Old 05-16-2013, 04:59 PM
aka Yamadog's Avatar
and watch out for the coolant/mattress tag police
I'm no diplomat
aka Yamadog is offline
