Air cleaner - Kawasaki Versys Forum
post #1 of 14 (permalink) Old 05-11-2013, 08:10 AM Thread Starter
jtwodogs's Avatar
Air cleaner
If I am reading the manual right. It says I have to take the tank off to clean the air cleaner.
Is this right?
Or am I reading this wrong?
Thanks for your help.
jtwodogs is offline
post #2 of 14 (permalink) Old 05-11-2013, 08:33 AM
Smiley's Avatar
That is correct, but not a big deal to do. There is discussion elsewhere here about removing the tank, check under valve adjust procedure, photos are included.
Smiley is offline
post #3 of 14 (permalink) Old 05-11-2013, 09:30 AM
Jeff S's Avatar
Yeah, this sounds worse than it is. Just do it when you're nearly out of gas (first time I did this, I had 2+ gal left, this time I syphoned it totally dry - it was certainly worth the time to syphon), and don't bother totally removing the tank - just swing it around 180 degrees with the front of the tank sitting where the back of the seat would be.
I just did this and my air filter was atrociously dirty. Also, there was a fair amount of stuff behind the air filter in the air box. Dead bugs, sticks, etc. I can't see any way this stuff could have gotten back there... Pulled it all out, buttoned it all back up, and all seems happy now.
Cheers, Jeff
2010 Versys
SW-Motech crash bars & bash plate
SW-Motech quick lock rear rack
Two seahorse 720 cases / panniers
Givi wind screen
Jeff S is offline
post #4 of 14 (permalink) Old 05-11-2013, 09:47 AM
Before removing the tank you have to remove a bit of plastic but its an easy job just takes time.
http://www.kawasakiversys.com/forums...ad.php?t=19448
post #5 of 14 (permalink) Old 05-11-2013, 11:40 AM
Just a word of caution re Jeff S's suggestion about not disconnecting the fuel line. It's a very expensive repair should the tank slip and break the nipple on the fuel pump, since you're looking at buying a new fp. IMHO it is better to get used to disconnecting the fuel line from the pump, so you can put the tank someplace safe while working on the bike. Cheers,
Doug
Mt. Versuvius is offline
post #6 of 14 (permalink) Old 05-11-2013, 12:00 PM
Is this right?
Be sure to also do a throttle body synch when you do this. It's a 2 min operation with the tank off. Suggest either buying the tool for this or building one. Also replace the spark plugs. See maint. section of the manual.
post #7 of 14 (permalink) Old 05-11-2013, 01:58 PM
Originally Posted by Jeff S View Post
...and don't bother totally removing the tank - just swing it around 180 degrees with the front of the tank sitting where the back of the seat would be....
Disconnect the fuel line and remove the tank! (I've posted a thread with pics, way-back-when.)
Doug
Doug's right.
post #8 of 14 (permalink) Old 05-11-2013, 05:43 PM Thread Starter
jtwodogs's Avatar
Thanks for all the great replies. Great community here!
Mine is an 09 with 2,900 miles all highway and garaged kept.
Do you think it rates this?
jtwodogs is offline
post #9 of 14 (permalink) Old 05-11-2013, 06:11 PM
I think the air filter is a pain in the ass to get to.
I can have the air filter out of my Dual sport or my ATV in 1 minute.
Takes 30 minutes to get to the air filter on my Versys
2009 Kawasaki Versys
2007 Honda XR 650L
2005 Kawasaki Brute Force 750
DK35vince is offline
post #10 of 14 (permalink) Old 05-11-2013, 06:56 PM
Time's Avatar
I have to agree, BUT I change the filter on the KLR monthly and the Versys gets cleaned maybe twice a year, I use it ONLY on road. I do wish UNI made a replacement for the Versys I have two for the KLR and always have a clean one ready to oil up and pop in.
BTW the plugs are just as big of pain on the KLR as the Versys to get at...and my Buell don't EVEN go there!
After checking the price of the fuel pump at $309.00 retail best price of $220.00 I pull the tank and set it WAY FAR AWAY.
Or was that look THEN leap?
2012 650 Versys
Time is offline
post #11 of 14 (permalink) Old 05-12-2013, 05:45 AM
If you've never looked at the air filter then I'd say yes, you should check it. At least then you have a baseline to work with. If you buy a second filter you can always have one clean and ready to swap in, which makes the whole job a lot faster (since you don't have to wait for the filter to dry after you've washed it, and before it can be re-oiled).
post #12 of 14 (permalink) Old 05-17-2013, 08:05 PM
Mursili's Avatar
Can you do a throttle body sync with the tank removed? Will the bike run?
Mursili is offline
post #13 of 14 (permalink) Old 05-17-2013, 08:52 PM
No!!!!! Unless you live down a dirt road or in the desert.
Photos of mine at 8500 miles..
IMG_0558 by weljo2001, on Flickr
IMG_0559 by weljo2001, on Flickr
post #14 of 14 (permalink) Old 05-17-2013, 09:06 PM
Engine needs the fuel tank and fuel pump to run, of course... Do it with airbox removed and rear of fuel tank propped up for easy access to TB vacuum bypass screws. Cover TB inlets with air filter element.
Here's the left throttle body's vacuum bypass adjustment screw at the end of red pointer, as seen from fuel tank's rear mount. leave the TB screw closed as it is, and adjust the other TB's screw to balance vacuum at 1300 rpm:
