What is this plug hanging down by shifter - Kawasaki Versys Forum
post #1 of 12 (permalink) Old 05-06-2013, 08:29 PM Thread Starter
I noticed this plug was just chillin hanging down by the vent tubes in front of the shifter. Looks like it should be plugged in somewhere but its not. My bike runs and pulls hard, it doesn't explode or call me names.
What is this plug for? Should it be reconnected to something?
And I know....look at all that oil everywhere...I got a little to happy with the gear oil on the chain this weekend and now its everywhere.
phildobaggins is offline
post #2 of 12 (permalink) Old 05-06-2013, 10:06 PM
King.Versys's Avatar
That is the flux capacitor relay pulley. You need to set the timing and year linkage and off you go.
King.Versys is offline
post #3 of 12 (permalink) Old 05-06-2013, 10:10 PM Thread Starter
I'm in Austin as well which is cool, but you suck at answering the question
post #4 of 12 (permalink) Old 05-06-2013, 10:20 PM Thread Starter
Looks like its also a common question on the 650r's
http://www.kawiforums.com/ninja-650r...oose-wire.html
post #5 of 12 (permalink) Old 05-07-2013, 06:24 AM
It is the connector for the oxygen sensor or lambda sensor bolted into the OEM exhaust.
This exhaust gas oxygen sensor or lambda sensor, is the key sensor in the engine fuel control feedback loop. The bike computer uses the O2 sensorís input to balance the fuel mixture, leaning the mixture when the sensor reads rich and enriching the mixture when the sensor reads lean.
Try taking a look from below the bike on the left side near the exhaust .
post #6 of 12 (permalink) Old 05-07-2013, 07:37 AM
True, and it's also a good idea to lubricate the flannelstan intake node with fauxmoly grease.
[SIZE="1"]Ride. Good.
2019 F750GS
2014 R1200RT
2008 Versys (SOLD 11/19)
2003 ST1300ABS (SOLD 5/15)
post #7 of 12 (permalink) Old 05-07-2013, 10:34 AM Thread Starter
The plug has a dust cover on it, looks like its just a diagnostic port or something unused on the versys.
post #8 of 12 (permalink) Old 05-07-2013, 10:40 AM
BLACK DOG's Avatar
I thought the diagnostic port was under the seat.
It probably is the plug for the O2 sensor that your bike DOESN'T have.
BLACK DOG is offline
post #9 of 12 (permalink) Old 05-07-2013, 11:32 AM Thread Starter
Well then there yah go, mystery solved.
post #10 of 12 (permalink) Old 05-07-2013, 12:01 PM
Hey Bones - isn't "fauxmoly" spelled with a hyphen... faux-moly...?
post #11 of 12 (permalink) Old 05-07-2013, 01:23 PM
Interesting observation.
I used a faux hyphen.
2019 F750GS
2014 R1200RT
post #12 of 12 (permalink) Old 05-10-2013, 04:26 PM
I think that if you remove the sprocket cover, you'll find it's the connector for the speedo pickup
09 Versys
00 KLR
USN 1959-65
ttpete is offline
