New Brake Pads - Kawasaki Versys Forum
post #1 of 17 (permalink) Old 05-06-2013, 06:32 PM Thread Starter
New Brake Pads
Recently replaced my stock front brake pads with EBC HH pads ($100CDN) after 21,000km. Original pads were worn enough for the mechanic to fail them on my mandatory safety inspection. The new pads offer an improvement in braking feel and are easier to modulate the braking force. They are much less grabby on initial application and the relationship between lever pressure and braking force is much more linear. Anyone else notice this?
post #2 of 17 (permalink) Old 05-06-2013, 07:12 PM
I just replaced the stocks pads after 15,000 miles for vesrah brake pads and the differance is night and day. The mechanic gave me the old ones because they were in such good shape to use if needed. The old ones are going in the garbage. I try not to use my brakes much. I get alot of people that follow me through the canyons and twisties that comment that i hardly hit my brakes. I like to use throttle control as much as possible.
post #3 of 17 (permalink) Old 05-06-2013, 07:18 PM
I just bought EBC organic brake pads today. Hopefully I like them as much as both of you like new pads. I have 25000 miles on my stockers.
08' Versys
HAWKSHOT99 is offline
post #4 of 17 (permalink) Old 05-06-2013, 08:18 PM
I also replaced the crappy stock pads with Vesrah RJLs. Only I did it before I even had 100 miles on the bike. Put on steel braided lines, too. Made the brakes much better. Coming from sportbikes with the latest and greatest brakes, I couldn't stand the Versys' brakes. Now they're quite tolerable!
HondaGalToo is offline
post #5 of 17 (permalink) Old 05-06-2013, 08:51 PM
CaptainShaq's Avatar
HondaGal, which braided lines did you get?
CaptainShaq is offline
post #6 of 17 (permalink) Old 05-06-2013, 08:54 PM
Yep i put the Galpher SS Lines on last year. Made an improvement but the pads were a bigger improvement.
post #7 of 17 (permalink) Old 05-07-2013, 06:35 AM
Zatx's Avatar
I may need to do this upgrade. I got on the brakes yesterday from about 60mph and felt like I was never going to stop. Was a disconcerting feeling...
Weljo.. got a link to what you bought? I did a quick google search but didn't turn up a version that went on the V.
Zatx is offline
post #8 of 17 (permalink) Old 05-07-2013, 06:41 AM
Tried EBC HH but Versah is better. Try the Sintered Metal Pad one.
http://catalog.vesrah.co.jp/list/brake.asp
post #9 of 17 (permalink) Old 05-07-2013, 07:22 AM
Hah... Good to hear about the obvious improvement with Vesrah pads... I had already put Vesrah pads on my new Versys for some reason, without ever trying the stock Tokico pads which are also HH but of a visibly very different compound.
Front Left: http://www.powersportsuperstore.com/...-p/4169902.htm
Front Right: http://www.powersportsuperstore.com/...-p/4177039.htm
(Rear): http://www.powersportsuperstore.com/...-p/4169912.htm
Vesrah (Japan) Brake pad listing: http://catalog.vesrah.co.jp/list/street_brake.asp
invader is online now
post #10 of 17 (permalink) Old 05-07-2013, 07:28 AM
Vesrah also has racing brake pads available in RJL, SRJL 17, and SRJL 8 compounds, as listed for EX-650 (#VD-354).
http://www.vesrah.com/new_page_56.htm
http://www.vesrah.com/new_page_42.htm
I like my Motul DOT 5.1 brake fluid as well, by the way.
http://www.motul.com/ca/en-US/products/77
post #11 of 17 (permalink) Old 05-07-2013, 08:17 AM
Galfer. Two line setup, one line from the master to each caliper with no T-junction. I ordered from solomotoparts.com because they have the color selection available and I wanted black lines. I have a '13, but the lines and pads they list for the '08-'10 fit. So do the Pazzo levers, I put those on, too!
I also had a double banjo bolt laying around that has a bleeder on it. Very helpful to also be able to bleed at the MC as well as the calipers. I forget where I purchased it, it was many years ago, but they're probably still around somewhere.
post #12 of 17 (permalink) Old 05-07-2013, 08:24 AM
Yes, I went with the RJLs. I got them from street and comp:
Right caliper http://www.streetandcomp.com/store/i...352RJL&eq=&Tp=
Left caliper http://www.streetandcomp.com/store/i...435RJL&eq=&Tp=
I've been using the RJLs for quite some time on my trackbike and have been happy with the performance, so I wanted the RJLs over Vesrah's other sintered pads.
The Motul DOT5.1 is good stuff. I put in the Motul 600RBF. Normally I don't use that in my street bikes, but the bottle was opened from doing the trackbike.
post #13 of 17 (permalink) Old 05-07-2013, 08:27 AM
ixion's Avatar
I have the black Galfer lines also (two line setup, no cross-line or "T"), and am very satisfied with them....love the ample "wave" in the rear line as well...got them from podiumsuperbikeinc on eBay. Pads are next.
ixion is offline
post #14 of 17 (permalink) Old 05-07-2013, 10:32 AM Thread Starter
Tweaking the front suspension also seemed to help braking, and handling too. I'm 190lb with gear and increased damping to 1.5 turns from max and preload to 6 turns from max. Still experimenting with this but the slight increase helped reduce front dive and front/rear pogoing while braking.
I did this on the advice of my shop after I mentioned how fast my front tires were wearing.
post #15 of 17 (permalink) Old 05-07-2013, 12:32 PM
Heres the pads i got...http://www.oemcycle.com/Cart?rnd=1367947170
Galpher SS Brake lines i got from a seller on ebay but i didn't see them listed today
post #16 of 17 (permalink) Old 05-09-2013, 10:39 AM
Thanks HondaGal
post #17 of 17 (permalink) Old 05-11-2013, 09:09 PM
DustyOne's Avatar
hey twowheels.....how did that suspension change go? Is it helping to control the bike and ride better?
prolly too early toget a tire reading unless you are racking up BIGTIME MILES
but a question on your previous tire wear; what were you running, and were they scalloping or just putting out uneven wear patterns?
thanks
DustyOne is offline
