Proble with lowering kit - Kawasaki Versys Forum
post #1 of 4 (permalink) Old 05-02-2013, 10:24 PM Thread Starter
Problem with lowering kit Install
I tried to install the Standard Lowering Kit and I can't get the shock to line up so I can get the bolt back in. If I had a tapered piece of steel the same diameter I could line it up but I don't. I have the bike on a rear axle stand but there is so much pressure from the shock.
Any advice. I don't have help so It's just me.
The piece needs to be lined up about 1/2 inch more so both bolts can go back in. If I try to force them I'm sure they will strip.
Is there another way to support the bike so it take pressure off the shock?
1Luckydog is offline
post #2 of 4 (permalink) Old 05-02-2013, 10:47 PM
You should not use a rear axle stand because the shock needs to be extended to enable installation of the lowering block. Raise the rear by placing jack stands (or even a gallon paint can) under each rider foot peg. Or rig an overhead sling as a few members have done. Regardless of the method, stability is very important. Good luck.
post #3 of 4 (permalink) Old 05-03-2013, 05:03 AM
+1 http://www.kawasakiversys.com/forums...1&postcount=14
post #4 of 4 (permalink) Old 05-03-2013, 08:23 PM
I put mine on with an Abba Stand. Best stand ever created for motorcycles.
revrandy is offline
Tags
install, kit, lowering, problem
