Pirelli Angel GT mileage guarantee - Kawasaki Versys Forum
post #1 of 26 (permalink) Old 05-02-2013, 01:37 PM Thread Starter
New Sport Touring Tires
Looks like the sport touring tire market is heating up with three new offerings.
Pirelli Angel GT
Michelin Pilot Road 4
Bridgestone BT30
post #2 of 26 (permalink) Old 05-02-2013, 08:57 PM
dxhFZ's Avatar
Thanks for sharing. Wonder what they changed compared to the Angel ST's? I have those now, amazing grip but disappointing mileage... If we get real user reviews on good mileage/grip on the GTs ill definitely consider them
Bikes:
65cc Benelli Dynamo
Yamaha ttr-125
Kawasaki KX-125
Yamaha Yz426-f (current)
dxhFZ is offline
post #3 of 26 (permalink) Old 05-02-2013, 09:28 PM
http://www.pirelli.com/tyre/ww/en/mo...subtype%3Droad
Originally Posted by dxhFZ View Post
Thanks for sharing. Wonder what they changed compared to the Angel ST's? I have those now, amazing grip but disappointing mileage... If we get real user reviews on good mileage/grip on the GTs ill definitely consider them.
It's all explained in twowheels' link:
"Compared to its predecessor, Angel GT increases mileage by 30 percent, reduces the braking distance by about 1 meter (at a speed of 75 kph), also improving grip and handling in the wet, and, even more importantly, manages to maintain these characteristics at a high level over time.
And so, with the name it chose for this product Pirelli decided to maintain a clear connection to the winning tyre, highlighting the evolution toward a product dedicated to long distances which maintains the typical sport spirit of Pirelli with the abbreviation GT.
This is why Angel GT is 100-percent Italian Gran Turismo, an ideal tire for those riders who travel long distances with a passenger and the bike fully loaded, or who simply take a ride in the country, but also for those who use their bikes all year round, both for recreation and commuting. All of this is true no matter what bike is used, whether a touring bike, a street enduro, naked or sport bike.
So Pirelli engineers managed to obtain standard-setting mileage in the segment combined with performance typical of a sport product but, what’s more, the unique feature of the Angel GT that sets it apart from the other products in the segment lies in the fact that the characteristics it boasts have limited degradation as kilometers roll by all the way to the end of the product’s life cycle. This is a property that Pirelli sums up as “Performance Mileage.”
The tread design
The Angel GT tread is a clear evolution of the Angel ST tread in technological terms because it was designed for the primary purpose of providing reduced and more regular wear and improved water drainage guaranteed by both the front tire and by the new arrangement of the grooves on the rear tyre.
To provide optimum wear, the grooves were directed following the theory of Schallamach wear waves which describes the mechanics of a wear crest forming on the tyre depending on the amount and direction of the forces exchanged between the tyre and asphalt at each point of the profile.
The arrangement and direction of the grooves were also studied in order to optimize water drainage and they allow a 10-percent reduction on the front and 16-percent reduction on the rear of the void/fill which translates into a larger surface of compound in contact with the ground and therefore better grip and better wear.
From a purely aesthetic point of view, the design is also neater and clearer. Unlike the Angel ST, the new Angel GT tread does not change its design with use, a testament to the fact that its performance remains essentially unaltered for the entire life cycle of the tire.
Profile
The target of increasing mileage, which cannot be achieved working only on the tread, took into maximum consideration the absolute need not to compromise grip levels needed to maintain performance and safety supremacy in any conditions of use. This is why the Pirelli Research and Development centre focused its efforts on achieving this improvement by also, and above all, designing a completely innovative profile.
Whilst maintaining the Pirelli philosophy based on a design with variable radius curvature, we worked on increasing the central radius by about 35% in order to create a less rounded central section. This way both the size and the proportion of the ground contact area were significantly modified, now 6% shorter and 15-percent wider compared to its Angel ST predecessor.
Generally speaking, a compound’s wear is caused by the sliding which occurs when it exits the surface area while the tire rolls on the asphalt. This is why the size and shape of the contact area with the asphalt have a direct impact on compound wear. A shorter contact area means less overheating, less sliding and therefore less wear of the compound itself.
At the same time, a 15-percent increase in width means being able to distribute wear over a larger portion of tread with an advantage for both final performance and more regular wear. By combining this technical solution with a specifically designed compound, Pirelli engineers were able to increase the mileage of the Angel GT by about 30 percent compared to the Angel ST.
A further benefit which stems from the profile lies in the fact that the contact area has a linear variation in its proportions between upright and fully leaned over bike, with the result of having a variable progression in tyre performance which provides the rider with a sensation of riding confidence and more agile and direct bike performance.
Structure
To adequately support the innovations made in terms of profile and larger road contact surface as well as guaranteeing a comfortable and pleasant ride, with the Angel GT tire a new rayon carcass was introduced which stems directly from the know how acquired by Pirelli in racing, particularly in the FIM World Superbike Championship.
The new carcass has 32 percent more linear density with 60 percent higher rigidity compared to the Angel ST tyre and at the same time it allows for an agile and direct ride, high push and grip in turns and excellent damping capacity on bumpy asphalt. It also guarantees that the initial performance of the new tyre will stay consistent for the entire life cycle of the product.
Compounds
Thanks to a tread contact area designed to improve mileage and to the benefits provided by the innovative profile and new structure which decrease the stress the compounds are subjected to, Pirelli engineers were able to decisively rethink the compound choices and the overall general philosophy for their application with respect to the Angel ST predecessor, achieving technical solutions which had been difficult to realize until now.
In fact, the Angel GT set is comprised of a rear made of a dual blend compound with cap&base technology, that is, a technology which allows the compactness and stability of the product to be improved using a compound intended to provide grip in the part in contact with the asphalt and a compound which guarantees stability on the lower layer, matched with a single blend on the front which uses a 100-percent silica formula derived from the one used on the shoulders of the rear tyre in order to provide similar performance, especially in leans and on wet roads.
The sophisticated construction of the rear, in addition to the cap&base application, provided a central part of the tread of about 45 millimeters in width (sizes vary slightly depending on the tyre size) created expressly to ensure extremely high stability at any level of load and use as well as greater resistance to abrasion and a high level of grip on wet roads both in acceleration and braking thanks to a silica concentration higher than 50% with a balanced proportion of carbon black and resins.
The shoulder compound, similar to the one on the entire front strip, is 100-percent silica capable of providing excellent grip on dry and wet surfaces thanks in part to the use of controlled microstructure polymers that improve filler dispersion and interaction between the polymers themselves and filler.
Particular care was taken in selecting these components in order to best harmonize the combination of the two compounds used and the revolutionary mixing process. In fact, the new compounds use innovative materials which unleash maximum potential if they are processed with a continuous mixing process, that is, a procedure which takes into consideration not only the volume of the ingredients used, but also the order in which they enter the flow.
Last but not least, the front tyre is also 100-percent silica, with a formula derived from the one used on the shoulders of the rear tire in order to provide extremely high performance on both dry and wet surfaces and in braking."
invader is online now
post #4 of 26 (permalink) Old 05-02-2013, 09:37 PM
dxhFZ's Avatar
Well here's hoping its true
Bikes:
65cc Benelli Dynamo
Yamaha ttr-125
Kawasaki KX-125
dxhFZ is offline
post #5 of 26 (permalink) Old 05-02-2013, 11:00 PM
http://www.pirelli.com/tyre/ww/en/ne...t-for-mileage/
The Motorrad TestCenter test
Angel GT is the best tyre for mileage in the Sport Touring segment. This was established and certified by the authoritative independent German body Motorrad TestCenter which conducted a test, comparing Pirelli with Michelin Pilot Road 3, Dunlop Sportmax Roadsmart II, Bridgestone Battlax BT 023, Continental RoadAttack2 and Metzeler Roadtec Z8 Interact M/O.
For the test, held in Spain from 27 November to 14 December 2012, a set of 120/70 ZR17 and 180/55 ZR17 tyres were used as the standard and six Suzuki Bandit 1250 ABS bikes were used. The test was conducted on fast roads between Málaga, Algeciras, Jerez, Seville, Cordoba and Antequerra at an average speed of 120kph and on country and mountain roads with speed limits between 90 and 110kph between Marbella, Ronda, Algodonales, Ardales, Alora and Málaga.
The test sessions were held in dry weather conditions with rather low temperatures, but consistent throughout the period. Due to the route that travelled through different altitudes (from 10 to 1100 metres above sea level) the air temperature varied from 18 to 5 degrees Celsius, while the asphalt temperature ranged from 18 to 23 degrees Celsius.
At the end of the test the Angel GT was found to be the tyre with the highest mileage compared to the competitors in the Sport Touring segment.
The design of the new Pirelli Angel GT tyre, the crowning jewel of the Milanese manufacturer’s Sport Touring segment, was completely finalised through innovative developments of new tread, profile structure and compound combination concepts aimed at achieving the ambitious status of absolute segment reference in terms of mileage performance without altering the typical Pirelli sport DNA for the entire life cycle of the product and providing standard setting performance on both dry and wet surfaces.
post #6 of 26 (permalink) Old 05-03-2013, 06:56 AM
Zatx's Avatar
And you can have the sidewalls personalized!
Zatx is offline
post #7 of 26 (permalink) Old 05-03-2013, 06:20 PM
RickySpanish's Avatar
so how many miles or your money back?
RickySpanish is offline
post #8 of 26 (permalink) Old 05-03-2013, 08:53 PM
No such warranty... They just swear that it does last and perform better and longer than the others, as proven in mileage riding comparison tests. It sure is a beautiful tire.
post #9 of 26 (permalink) Old 05-04-2013, 08:07 AM
Time's Avatar
I had Pirellis Scorpion Syncs on my Buell and went through them like popcorn. I put a set of Scorpion Strata and they were the last set of Pirellis. While they lasted longer they made the bike handle like a truck. I put a set of Michelin RP2s on it and was very happy.
Fast forward and the Buell had been replace with the Versys. Time for tires today as a matter of fact. Going with the Michelin RP2s on it. I have Michelin T63 Big Block knobbies on my KLR and have been impressed with them no end. Not just off road but on road as well. Add to this that at 2,000 miles they look almost new. I should see 6,000 PLUS out of them. NOT bad for this type of tire. BUT at 65+ they sing like you can''t believe!
Or was that look THEN leap?
2012 650 Versys
Time is offline
post #10 of 26 (permalink) Old 05-04-2013, 01:48 PM
Originally Posted by Time View Post
...I have Michelin T63 Big Block knobbies on my KLR and have been impressed with them no end. Not just off road but on road as well. Add to this that at 2,000 miles they look almost new. I should see 6,000 PLUS out of them. NOT bad for this type of tire. BUT at 65+ they sing like you can''t believe!
When I had a KLR, I ran Kenda K270s on it. I regularly got north of 10,000 miles from the rear, and 12,000 from the fronts. Like your T63s - they DO sing, but after the center "squares". They worked well ON and OFF road.
post #11 of 26 (permalink) Old 05-04-2013, 09:39 PM
andrewhtf's Avatar
pirelli with new GT, bridgestone with new T30, I wonder what Michelin will replace its PR3 with...
Current : Maroon 2011.
Up next :
andrewhtf is offline
post #12 of 26 (permalink) Old 05-04-2013, 10:23 PM Thread Starter
Pirelli and Metzler are the same company
Sent from Motorcycle.com App
post #13 of 26 (permalink) Old 11-12-2013, 02:01 PM
LittleRedRooster's Avatar
Pirelli Angel GT Evaluation
November 2013 Cycle World rode the Angel GT on a variety of bikes including the Versys and said "it provided uniformly excellent feel and a high degree of confidence and stability." Obviously there was no durability insight, but as a lower mileage rider longevity is less of an issue with me.
LittleRedRooster is offline
post #14 of 26 (permalink) Old 11-12-2013, 03:51 PM
They come stock on the bike i'm currently drooling over....
MTS-1200S-Granturismo_2014_Studio_R_B01_1920x1080.mediagalle ry_output_image_[750x423] by weljo2001, on Flickr
post #15 of 26 (permalink) Old 11-12-2013, 05:36 PM
Have you got the link to the test done by the germans Invader?
post #16 of 26 (permalink) Old 11-12-2013, 08:01 PM Thread Starter
updated original post with other new sport touring tires recently introduced.
post #17 of 26 (permalink) Old 11-13-2013, 04:06 AM
Daedalus62's Avatar
Durability?...
My Michelin Pilot Power 2CT rear... Around 20K km (12K4 miles) on it now... And it's not getting replaced soon...
On the other hand (erhh... end), my front... Around 40K km (24K8 miles) on it... Getting replaced this week, rainy season is coming...
Get them while they last... They were discontinued
Cheers
Daedalus62 is offline
post #18 of 26 (permalink) Old 11-13-2013, 06:45 AM
for the info, Still with Bridgestone S20.
post #19 of 26 (permalink) Old 11-13-2013, 08:44 AM
Lours_Polaire's Avatar
A very droolable bike indeed !!!
LOP
Lours_Polaire is offline
post #20 of 26 (permalink) Old 11-13-2013, 04:22 PM
Freerydejunky's Avatar
Interesting that they came out with the PR4 already. With everyone raving about the PR2 and PR3 it is great to see a company constantly making improvements on their tires even though people can't seem to say a bad thing about them!
I have BT-023's on my Versys now and hate them. The rear had a huge flat spot. It is cupping like no other tire I've ever had.
I just picked up a set of ContiForce for 50 bucks with stickers on them. Yes, that's right, 50 bucks. Once they wear out I will pony up the money and get a set of PR3's I suppose.
My SV650 has had RoadSmart 2's for the last 15k. The front still looks bran new, the rear has easy another 7-10k on it. But I have had it slip quite a bit in the winter months. If you are concerned about long tire life, it is hard to pass up the RoadSmarts.
I'll wait to see what the new GT's are all about, my buddy has done 8k on them on his SV and says they have at least another 8k on them. But the SV is a good bit lighter...
Hooligan
Freerydejunky is offline
