Electrical question - Kawasaki Versys Forum
post #1 of 11 (permalink) Old 04-22-2013, 12:46 PM Thread Starter
G19Tony's Avatar
Electrical question
Related to my Stebel horn.
It's connected to a Fuzeblock on a 10 amp fuse. The fuse blew, can I get a 15 amp fuse, or is there an underlying problem I need to sort out first?
Thanks.
G19Tony is offline
post #2 of 11 (permalink) Old 04-22-2013, 01:33 PM
BLACK DOG's Avatar
I would probably try to find out what size fuse was required before substituting at random (I here a .22 cartridge fits well).
If you don't KNOW what is supposed to be there, you don't KNOW you have a problem or how bad it is.
just sayin
BLACK DOG is offline
post #3 of 11 (permalink) Old 04-22-2013, 01:39 PM
For the Stebel - 15 Amp!
post #4 of 11 (permalink) Old 04-22-2013, 03:35 PM
DustyOne's Avatar
Eddie is sharp on the stuff needed for these bikes, so trust his info.
And I see you are wired thru your FB, that is good.
But just remember that if you remove the FB or decide to wire your horn back to stock, you will definitely need to add a separate relay due to that particular horns electrical draw.
Of course, everyone here prolly already knows that except me, and I just learned it here:
http://www.kawasakiversys.com/forums...ht=stebel+horn
We all have are knowledge banks and brain wrinkles. Electricity IS NOT one of mine!
DustyOne is offline
post #5 of 11 (permalink) Old 04-22-2013, 04:44 PM Thread Starter
G19Tony's Avatar
Thanks friends. I picked up a 15 amp fuse and I'll be installing it in a minute.
G19Tony is offline
post #6 of 11 (permalink) Old 04-22-2013, 07:27 PM
just want to add that you should make sure the wire you used is rated to handle 15 amps.
http://www.engineeringtoolbox.com/am...uge-d_730.html
post #7 of 11 (permalink) Old 04-23-2013, 12:56 AM Thread Starter
G19Tony's Avatar
I'll check tomorrow. He used some pretty heavy wire. Thanks for the reminder.
G19Tony is offline
post #8 of 11 (permalink) Old 04-23-2013, 03:50 AM
andrewhtf's Avatar
At least a 14- or 12- gauge wire.
Current : Maroon 2011.
Up next :
andrewhtf is offline
post #9 of 11 (permalink) Old 04-23-2013, 08:34 AM
Lours_Polaire's Avatar
More important than the device at the end of the wire ...
LOP
Lours_Polaire is offline
post #10 of 11 (permalink) Old 04-23-2013, 11:09 AM
Tony - I learned that when I 'tried' a 10 amp fuse (I was out of 15 amp ones) in my FZ-1 at first. It worked UNTIL I gave a more-than-a-short honk, blew, and I went to O'Reilly's to get a pack of 15's and did what I SHOULD have done in the first place.
post #11 of 11 (permalink) Old 04-23-2013, 05:49 PM Thread Starter
G19Tony's Avatar
The 15 works fine. There is some pretty heavy gauge wire on the horn. I'm confident everything will be fine. Thanks again for the advice.
G19Tony is offline
