Hoses next to the kickstand spring - Kawasaki Versys Forum
post #1 of 6 (permalink) Old 04-20-2013, 06:43 PM Thread Starter
I was doing my chain cleaning/lubing on my 2013 V when I noticed these 2 hoses sticking out under the the exhaust, right next to the kickstand spring. One of them- the shorter one is attached to a small plastic container (not seen on photo) , which was empty. The longer one was just hanging down. I suspect they are supposed to be there since there is a plastic thingy holding them in place. I pulled them both up a bit so they are not hanging down as shown on the
pix.
Can anyone tell me what these are for? In the meantime, I will try to find them in the manual. Thanks in advance.
Name:	hose by the stand2.jpg
ID:	20097   Click image for larger version
Name:	hose by the stand1.jpg
ESE_VERSYS2013 is offline
post #2 of 6 (permalink) Old 04-20-2013, 06:52 PM
Fuel overflow and i believe one is from the air box.
post #3 of 6 (permalink) Old 04-20-2013, 08:11 PM
Small plastic container? The airbox hose should be clear with a black plug on the end, and it should come down on the other side behind tranny.
invader is online now
post #4 of 6 (permalink) Old 04-20-2013, 11:11 PM
genehil's Avatar
Both tubes come down from the fuel filler area. One of mine had a bad kink in it from the factory and once I straightened out the kink a fair amount of fuel and whoknowswhat drained out onto the garage floor.
http://www.kawasakiversys.com/forums...ad.php?t=18558
GeneHil - Mount Dora, FL
2011 Kawasaki Versys
genehil is offline
post #5 of 6 (permalink) Old 04-20-2013, 11:24 PM
genehil's Avatar
You can see where they attach near the circled A in the diagram below...
genehil is offline
post #6 of 6 (permalink) Old 04-21-2013, 12:30 AM
The front fuel tank hose has a breather/filter on it. Rear fuel tank hose is the overfill/water drain... My 2007 has only the rear drain hose.
