anybody seen this before??????? - Kawasaki Versys Forum
post #1 of 15 (permalink) Old 02-17-2009, 02:36 PM Thread Starter
pensionera_gmp's Avatar
i recently got this white thing that looks like foam which never disappears. has any of you have that too? seen it? is this a problem?
pensionera_gmp is offline
post #2 of 15 (permalink) Old 02-17-2009, 04:24 PM
Nortasaki's Avatar
Yep, condensation. Maybe an oil addative like STP will help at your next oil change.
Nortasaki is offline
post #3 of 15 (permalink) Old 02-17-2009, 07:18 PM
Chicken Little's Avatar
Hmmmmmm.
Chicken Little is offline
post #4 of 15 (permalink) Old 02-17-2009, 09:34 PM
IF the 'white stuff' is in your oil viewing window, it's PROBABLY caused by your oil not getting hot enough to 'boil off' the water.
RIDE MORE AND LONGER!
post #5 of 15 (permalink) Old 02-17-2009, 09:54 PM
demuire's Avatar
Send a message via MSN to demuire Send a message via Skype™ to demuire
Umm, isn't it bad to have water in your oil? Isn't that a sign of a blown head gasket or something similar?
demuire is offline
post #6 of 15 (permalink) Old 02-17-2009, 10:05 PM
How many miles on the mysterious white foaming bike?
post #7 of 15 (permalink) Old 02-17-2009, 10:22 PM
Sight glass
I had it form in mine once went away after I rode it and got it hot.
justgettingit is offline
post #8 of 15 (permalink) Old 02-19-2009, 04:32 AM
If you only make short rides there will be a significant amount of condensation in the crank case that will cause some foaming. It will not hurt anything and will boil away when the engine gets to full operating temp. It is a good excuse to go for a nice long ride.
TAC650 is offline
post #9 of 15 (permalink) Old 02-19-2009, 02:23 PM Thread Starter
guys i just found out that the pic didnt upload. here it is. it's on the "oil viewing window" or whatever else you guys call it. ?
post #10 of 15 (permalink) Old 02-19-2009, 02:54 PM
That is condensation
If getting it hot on a long ride doesnt fix it it may be external and caused by cleaning fluids/solvents. Did you try plastic polish on the outside?
Any strange cleaning done on the V?
2xadv is offline
post #11 of 15 (permalink) Old 02-19-2009, 03:16 PM
no probs
what you can see is condensation in the oil sight glass, I presume that its cold were you live at the moment, The difference in outside temperature to that inside creates this milky effect. It should disappear once the engine has reached normal operating temps, if it remains then get your service agent to have a look but I would guarantee that it goes... Also remember during winter lay up it does your engine more harm if you just start it up and run it without actually riding it and putting it under normal operating loads, Better to leave it until you can ride it, Keep the battery on trickle charge to keep it in good condition,,,,
yoyo is offline
post #12 of 15 (permalink) Old 02-19-2009, 04:16 PM
xprovince's Avatar
My bike has that too but its from the weather and short rides
V
xprovince is offline
post #13 of 15 (permalink) Old 02-19-2009, 07:13 PM
Skeezix's Avatar
I had the same problem, and after MANY hot miles, it didn't go away. There are only two things you can do to get rid of it. First, you can change the oil - but make sure it's HOT before you drain it. Most condensation occurs when the oil is cold and THEN changed. Second, you can add SEAFOAM which is a fuel/oil additive that you can get at any auto store, and maybe even Wal-Mart. I've used it for YEARS in everything from my car to motorcycles, to lawn mowers, to R/C airplanes.
'I use my cigar smoke as idiot repellent'
Yeah, that’s a statistic sample size of 1, category “anecdotal evidence”, but there it is.
"You just got killed by a Daewoo Lanos motherfu#&er!!" -Red, from Pineapple Express.
Skeezix is offline
post #14 of 15 (permalink) Old 02-19-2009, 07:38 PM
Red Herring's Avatar
X2
Red Herring is offline
post #15 of 15 (permalink) Old 02-20-2009, 06:41 AM Thread Starter
this is what i thought guys. it is very cold where i live and i used to start it once in a while in winter without actually riding it and i think that this is what caused it. 6k miles. it is time for an oil change so i will try to do whatever you guys said it should help. Thank you very much. you r really helpful.
