Technical advice - installing handguards - Kawasaki Versys Forum
post #1 of 18 (permalink) Old 02-03-2009, 07:33 PM Thread Starter
Since I'm rather dimwitted when it comes to mechanical things, I need some advice from you gurus out there. My Acerbis Multiconcept handguards arrived today. While their product seems good their instructions suck big time. After looking at Acerbis instructions I will never complain about Ikea again.
My question relates to the bar end attachment. There is an Acerbis expanding widget that goes inside the handlebars. So far so good. There is also a rubber sleeve. Am I to assume that the rubber sleeve goes over top of the expanding widget? Also, once I start to take the bar ends apart are there any parts that will go sproing!! and roll into a dark corner never to be seen again?
I welcome any and all advice.
Thanks for your help...
Oh yeah, one more thing: Has anyone tried getting rid of that big, ugly Acerbis emblem like with some paint? I don't want my bike to look like a billboard.
charly is offline
post #2 of 18 (permalink) Old 02-03-2009, 08:57 PM
DragonBreath's Avatar
Charly,
I have the same handguards with the large Touring wind deflectors.
You're in luck. The end of the handlebars are threaded to accept the OEM bar end weights. You can just unscrew the bolt holding the existing weights and use that same screw to hold in the end of your new handguards. The taper of the bolt head is exactly the same as that on the expansion bolt assembly you pictured. It will nest just right into the taper of your handguard.
You can save the expansion widgit for a rainy day.
As for removing the Acerbis logo, I wish I had some sage counsel. I agree with you that I would rather not be a rolling commercial for Acerbis or any other manufacturer for that matter. I considered solvents, but I'm afraid of messing up the finish on the plastic. I also considered scraping them offer, but again, fearful off messing up the surrounding bits. I also noticed that the letters are not just painted or stuck on. They appear to be slightly raised from the surface as if they are actually part of the injection mold.
I will keep an eye on this thread in hopes that someone can solve this problem for us.
You should be good to go on the mounting though.
Chris in Oneonta, NY
>>>> states on a bike <<<<
>>>> East Coast done <<<<
>>>>> Westward HO! <<<<<
DragonBreath is offline
post #3 of 18 (permalink) Old 02-03-2009, 09:35 PM Thread Starter
Thanks DragonBreath. Here's another dumb question: Do I use the Kawasaki bolt or the Acerbis widget bolt? Is the Kawasaki bolt still long enough to do what it's supposed to do considering the thickness of the handguard bracket?
charly is offline
post #4 of 18 (permalink) Old 02-03-2009, 09:42 PM
Charly, I'm pretty sure I re-used the Kawi bolts, but either will work. I think the handguard aluminum bar is no thicker than the portion of the bar end that the existing bolt is holding.
If you're uneasy with that, it's no problem to remove the long bolts from the expansion assembly and use them. I think I remember checking that and noting that the thread pattern is the same. I might be wrong with that though.
EDIT: One thing I just remembered. I am pretty sure the existing bolts are red-loctited in, so don't be surprised if you have to really get on them with an allen-wrench to get them to break free. If you can't get them to budge, you can always heat the bolt a bit with an air gun or soldering iron. Watch out for over heating the grip though. Good luck.
>>>>> Westward HO! <<<<<
post #5 of 18 (permalink) Old 02-04-2009, 06:56 AM Thread Starter
The emblem appears to be paint. It's not molded in. I held the handguard over a steaming kettle and was able to scrape some of the emblem off. I don't recommend doing it that way, though. It scuffs up the finish of the plastic.
charly is offline
post #6 of 18 (permalink) Old 02-04-2009, 07:45 AM
redline's Avatar
I have the same guards. I didn't try to remove the logo yet, but it's on my list of things-to-do. Once the paint is removed, minor scratches can be buffed out. I've already done this to these guards from inadvertently scraping one on my garage door. The gouge was sanded and it buffed out fine. I'll try some acetone or paint remover and see if that works. Going on vaca for awhile so I won't be able to report back till around the 20th or so.....
redline is offline
post #7 of 18 (permalink) Old 02-04-2009, 10:31 AM
Redline, definitely report back when you can though, because this is something that I really want to do. I have been hesitant to try just because I don't want to turn a little problem into a big one.
Have a good vacation
>>>>> Westward HO! <<<<<
post #8 of 18 (permalink) Old 02-04-2009, 11:15 AM
redline's Avatar
No problem. I'll keep you informed. It'll come off one way or the other...
redline is offline
post #9 of 18 (permalink) Old 02-05-2009, 08:30 PM
amir_zwara's Avatar
I got half of the acerbis logo off of one of mine.
All it takes is grinding the guards into the asphault. Though there may be better ways to go about this...
amir_zwara is offline
post #10 of 18 (permalink) Old 02-09-2009, 06:09 PM Thread Starter
Spray paint works. I bought a spray can of promoter and a spray can of black auto body touch up paint. Cleaned the guard with degreaser, sanded it, masked it off and sprayed it. No more logo.
I hope spring comes soon. I'm getting a little anal with the modifications.
charly is offline
post #11 of 18 (permalink) Old 02-09-2009, 08:38 PM
juevea12's Avatar
Hand gaurds
Just put some acerbis hand gaurds on mine and used aircraft remover,the acerbis wipes off instantly and does not damage the plastic.
juevea12 is offline
post #12 of 18 (permalink) Old 02-10-2009, 05:41 AM
juevea12, this is good news. I'm not familiar with aircraft remover. What is it and where can I get some.
Thanks.
>>>>> Westward HO! <<<<<
post #13 of 18 (permalink) Old 02-10-2009, 08:42 AM
juevea12's Avatar
Hand gaurds
It is paint remover you can get it at a auto parts store,its in a blue can.Be careful not to get it on your skin.
juevea12 is offline
post #14 of 18 (permalink) Old 02-10-2009, 09:05 AM
Wordguy's Avatar
I thought you weren't supposed to use Aircraft remover on plastic? Is there a type for use on plastics too?
-Alan
Wordguy is offline
post #15 of 18 (permalink) Old 02-10-2009, 09:08 AM
juevea12's Avatar
had gaurds
I thought the same thing so i tried it on a extra dirtbike fender i have and waited a day and it did not do any thing to it.Also spray it on a rag then wipe it off as you do not want any overspray on your bike paint.
juevea12 is offline
post #16 of 18 (permalink) Old 02-20-2009, 11:24 AM
AvaChava's Avatar
I'd pay five bucks more for the handguards without
the billboards. Somebody ought to tell Acerbis!
AvaChava is offline
post #17 of 18 (permalink) Old 02-20-2009, 11:39 AM Thread Starter
So would I, considering I spent twenty bucks in supplies to paint over top of their bloody logo.
charly is offline
post #18 of 18 (permalink) Old 02-25-2009, 06:32 PM
redline's Avatar
I used what I had sitting on my bench......rubbing compound works well with a scouring pad. I haven't had the chance to go at it with the buffer yet, but the logos came off in about 5 seconds......it did "scuff" up the plastic and leave it dull, but that's what happened with the scratch that buffed out fine. I'll get to finish it this weekend....
Update: The buffer did not do the job as good this time as the original smaller scratch removal did. Bottom line is that the shiny sheen is now like a flat black. Certainly not bad, but this procedure is not recommended.
redline is offline
