radiators which one do I have - Kawasaki Versys Forum
post #1 of 2 (permalink) Old 03-31-2013, 11:05 AM Thread Starter
DustyOne's Avatar
Hi all. New guy here and I need little bit help please.
I bought many parts last year and bought more of my own.
Also used some from extras I have built in my own supply from many
years of working motorbikes.
I need help to identify a radiator that I have mounted to my Rat Bike.
Big parts are this:
All parts are 2008 years
Versys motor
Versys fork and swingarm
Ninja 650R frame and fuel tank
Radiator?????
I do not know this from which motorbike.
I have read the 650R Radiator is smaller.
But I have nothing to compare it to.
I need new Rad Cap, and they are different from Versys and Ninja 650R Radiators and Caps.
The current radiator is mounted what looks normal mount on 650R Frame.
I have a crashed Versys frame but front is damaged where radiator would mount.
Can someone help? If size is different please measure the one you have if you can get under the covers to tell.
Thank you
dustyone
DustyOne is offline
post #2 of 2 (permalink) Old 03-31-2013, 11:21 AM Thread Starter
DustyOne's Avatar
Ah ha.
I have found the answer I believe. Wife said to look at pictures in parts website, OEM.
And yes, I find the side mounts for left side are even with the end of radiator for my part.
This matches the picture for the 650R OEM part.
So this is me!
The radiator on Versys, the left side mounts are welded to the inside of the edge. This part is longer than the 650R radiator. It does look that mountings are at same locations but I might be telling incorrect information on this point.
If frame mounts are same locations, yes it would be possible to bolt on either radiator to either framem. I am sure that you smarter people can give the most correct answer to this technical question, yes?
So I answer my own question, well, I should say, my smarter wife answer question
DustyOne is offline
