Chain Replacement Question - Kawasaki Versys Forum
post #1 of 10 (permalink) Old 03-29-2013, 01:08 PM Thread Starter
Tgoods's Avatar
I'm getting ready to replace the chain & sprockets this weekend. I've got a chain breaker, but do I need a special tool to install the master link?? Below are the chain parts I bought from Bike Bandit.
Western Power Sports 520 HSO O-Ring Motorcycle Chain Rivet Master Link
Also, has anyone done a write-up of a chain & sprocket change yet?
Beauty is in the eye of the beer-holder
Tgoods is offline
post #2 of 10 (permalink) Old 03-29-2013, 01:43 PM
tenover's Avatar
I'll be doing the same thing, probably tonight or this weekend. I ordered a kit that someone recommended on this forum that included the chain and both sprockets for $160 I believe. I also brought a chain tool kit with the breaker, anvils, posts, etc....Also bought a long breaker bar and the correct sized sockets for the wheel nuts (14mm, 22mm and 27mm if I remember correctly).
tenover is offline
post #3 of 10 (permalink) Old 03-29-2013, 02:34 PM
cuff's Avatar
There are a few threads around here about getting the front sprocket off if this is the first time for you. Bit of a job for most.
The master link you bought has rivets that need to be installed in a certain way that involves rounding over the rivets with a specialized tool. It can be done with other tools but if you haven't done this before I wouldn't recommend it.
IBA# 38547
cuff is offline
post #4 of 10 (permalink) Old 03-29-2013, 04:24 PM Thread Starter
Tgoods's Avatar
Crap... well I do have the Versys tech manual so I will have to go through that in detail and figure out what I need. I'm sure Harbor Freight sells a tool that will get the job done.
Tgoods is offline
post #5 of 10 (permalink) Old 03-29-2013, 04:34 PM
Time's Avatar
What you need is a set like this, it's a Tusk set that I bought at about half the price of the big brands. Work well and I paid about $50.00 for it.
Or was that look THEN leap?
2012 650 Versys
Time is offline
post #6 of 10 (permalink) Old 03-29-2013, 05:14 PM
I have the RK chain breaker and rivet kit, one of the best ones, IMO. Motomummy sells it for a good price.
HondaGalToo is offline
post #7 of 10 (permalink) Old 03-29-2013, 05:30 PM
post #8 of 10 (permalink) Old 03-29-2013, 05:47 PM
I use a grinder to grind off the rivet and a chain tool to set the rivet on the master.
Newsshooter is offline
post #9 of 10 (permalink) Old 03-29-2013, 06:33 PM
Motion Pro Mini Chain Press Tool http://www.powersportsuperstore.com/...-p/4451774.htm
Motion Pro Chain Breaker Press and Riveting Tool http://www.powersportsuperstore.com/...-p/4451780.htm
I got the Motion Pro Mini Press Tool to press main link on, then used a hammer and punch to rivet, with the back of chain pins sitting on secured steel rod.
post #10 of 10 (permalink) Old 03-29-2013, 11:38 PM Thread Starter
Tgoods's Avatar
Invader UDM
Tgoods is offline
