4 way flashers inop - Kawasaki Versys Forum
post #1 of 6 (permalink) Old 01-26-2009, 02:48 PM Thread Starter
rbl
4 way flashers inop
My signals all work fine, but my hazards do not. When I push the button the lights flash once and then stop, have to cycle the power to get the signals to start working again. Any thoughts? Has anyone had this issue? I hate electrical gremlins! My first thought is the flasher relay but I am uncertain as to its location.
Richard
RBL
07 Versys, orange.
givi e21's & pelican 1550
warm&safe dual heattroller
fender extender (unknown brand)
rear hugger
madstad bracket
vario windscreen
handguards (dr650?)
klr front and rear signals
hb crashbars
flatfoot
lowering pegs
ctech fuse panel
rbl is offline
post #2 of 6 (permalink) Old 01-26-2009, 03:01 PM
xprovince's Avatar
I had the same issue but it was after I changed my turn signal bulbs to amber and my turns signal lenses to clear . It was the watts that the bulbs were at , I replaced them with a higher watt bulb and that started to make the hazzards in-op.
V
xprovince is offline
post #3 of 6 (permalink) Old 01-26-2009, 03:23 PM Thread Starter
rbl
Click! A-ha, I just changed to the klr clear signals. Didn't make the connection there since the signals still work. Did you switch back to a lower wattage bulb or live without hazards? Brighter signals or hazards, which is better? I am wondering if it is a standard hazard relay and I can replace it with a beefier one. I noticed the 09 versys has clear lenses, so might be worth checking what bulbs or hazard relay is in it.
RBL
07 Versys, orange.
rear hugger
madstad bracket
vario windscreen
handguards (dr650?)
hb crashbars
flatfoot
lowering pegs
ctech fuse panel
rbl is offline
post #4 of 6 (permalink) Old 01-26-2009, 03:50 PM
xprovince's Avatar
lol yeah I left the higher bulbs in , I use the signals more than the hazards, and yeah those bulbs are what Im going to have to order , I do like how bright mine are. so its a toss up dealing with my local Kawi shop (SGpowers) or not have hazards.. but I hate trying order light bulbs from my local dealership they just want to match what they have in stock...
V
post #5 of 6 (permalink) Old 01-26-2009, 05:36 PM
The Gorilla's Avatar
The Gorilla is offline
post #6 of 6 (permalink) Old 01-27-2009, 04:48 PM Thread Starter
rbl
Originally Posted by The Gorilla View Post
I'll check into that once I have mine out to compare. Verified through Kawasaki that the flasher relay is the same 2007-2009, so worst case I can switch to stock 2009 bulbs. It's a novelty to own a bike with hazards.
RBL
07 Versys, orange.
rear hugger
madstad bracket
vario windscreen
handguards (dr650?)
hb crashbars
flatfoot
lowering pegs
ctech fuse panel
rbl is offline
