2 things....about stripping - Kawasaki Versys Forum
post #1 of 7 (permalink) Old 03-24-2013, 04:59 PM Thread Starter
1. The a-hole who took delivery and did the pre-sale assembly stripped 2 of the welded nuts that mount the left fairing. Seems like both were stripped in the middle probably due to careless work and a bad approach angle...that's what she said.
2. I found 7 total loose bolts with the worst being the lower bolt on the coolant expansion tank...its just plumb fell off the bike when I breathed on it.
Anyways I have never tapped my own holes
So I rode on down to harbor freight and picked up a 40 piece tap/die set. Used the guage to verify the 1.0mm threading and found the correct tap. After watching 2-3 youtube vids on tapping holes I revived both nuts.
I lubed up before tapping, and only tapped it a little before backing off and getting deeper. When I detected any resistance I just added a little lube before tapping any deeper....
On a more real note, I did a 3/4 turn righty tighty, 1/2 turn lefty loosy and it came out great. I sprayed the tap down with walmart generic wd40 before tapping, make sure its lined up and following the initial thread groove, super easy.
phildobaggins is offline
post #2 of 7 (permalink) Old 03-24-2013, 05:13 PM
Time's Avatar
That's the stuff. As a die maker/machinist I've done my share of tapping and chasing threads. You have the right motion going. 1-2 turns in then back out a turn to clear the chips. chasing (re-threading) a messed up holes can be tricky if it was cross threaded as you stand a chance of binding up and breaking a tap. Then you have all kinds of fun.
Glad you got it fixed up.
Or was that look THEN leap?
2012 650 Versys
Time is offline
post #3 of 7 (permalink) Old 03-24-2013, 05:20 PM Thread Starter
Yeah Im glad too. Ill say that the most important thing to me during that process was patience, I tried purposefully to take my time, still only took a few minutes to clean up the threading even when going slow. I also ran the tap through a few times to make sure the threads would nice and smooth and test fitted with 2 bolts afterwards hand tightening only.
post #4 of 7 (permalink) Old 03-25-2013, 12:03 PM
I use blue Loctite when I re-install the bolts into my V, so every now-and-then I "chase" the threads ON the bolts, and INTO the 'nut' portions on the frame to get rid of accumulated "gunk".
Good practice.
post #5 of 7 (permalink) Old 03-26-2013, 09:41 AM
Lours_Polaire's Avatar
Maybe not possible in your specific situation, but helicoil is also a nice way to repair a damage hole/thread
LOP
Lours_Polaire is offline
post #6 of 7 (permalink) Old 03-26-2013, 10:01 AM
ROFL - AWESOME
<----- Check Out My Blog!!!
2006 Ninja 500 - Bone Stock & Beautiful
2008 Versys - Farkled To The Max
06EXTN is offline
post #7 of 7 (permalink) Old 03-26-2013, 10:18 AM
El Tig's Avatar
Hilarious! Glad it worked out.
El Tig is offline
