What size socket to remove the spark plugs??? - Kawasaki Versys Forum
post #1 of 16 (permalink) Old 03-23-2013, 07:35 PM Thread Starter
tenover's Avatar
got the extension(DAMN that's tight in there!)......But what size socket is needed to actually remove the plugs? Thanks.
tenover is offline
post #2 of 16 (permalink) Old 03-23-2013, 08:10 PM Thread Starter
tenover's Avatar
Seems like a 5/8 socket, and I think I loosened it up, but how do you get them out???? Do you have to fish down there with grabbers or something??!?
tenover is offline
post #3 of 16 (permalink) Old 03-23-2013, 08:25 PM
BLACK DOG's Avatar
I always have an extendable magnet handy whenever I take something apart, even if it's non-magnetic.
BLACK DOG is offline
post #4 of 16 (permalink) Old 03-23-2013, 08:26 PM Thread Starter
tenover's Avatar
The tool in the Versys kit worked GREAT for one....LOL. The second one is totally loose but will not come out. Uggghhh......
tenover is offline
post #5 of 16 (permalink) Old 03-23-2013, 08:30 PM
kenr74's Avatar
Are you using a spark plug socket? They usually make short work of pulling out plugs.
kenr74 is offline
post #6 of 16 (permalink) Old 03-23-2013, 08:36 PM Thread Starter
tenover's Avatar
I'm using the one that comes in the versys tool kit, which worked perfectly for one of them. The other one just seems "loose" and won't come up with the socket.
tenover is offline
post #7 of 16 (permalink) Old 03-23-2013, 08:59 PM
It's 16mm (5/8"). A 5/8" spark plug socket works, or a good magnet.
post #8 of 16 (permalink) Old 03-23-2013, 09:07 PM
Oh, you can try picking it up by sticking the coil back in.
post #9 of 16 (permalink) Old 03-23-2013, 09:17 PM Thread Starter
tenover's Avatar
FINALLY got it...after tightening it back in 50 times and pushing DOWN while loosening. Thanks guys. I even went down to AutoZone and bout a flexible extension with a magnet and also one of those 4-pronged flexible "grabbers".....As soon as I got home and tried one more time with the socket, it worked....LOL. Oh well, at least I have two new "tools" now....
tenover is offline
post #10 of 16 (permalink) Old 03-23-2013, 09:18 PM Thread Starter
tenover's Avatar
Unfortunately autoZone didn't have the plugs(NGK CR9EIA-9 6289 Iridium) though....So I have to try and track those down locally tomorrow
tenover is offline
post #11 of 16 (permalink) Old 03-23-2013, 09:19 PM Thread Starter
tenover's Avatar
Quick question....Since I'm this far down into the bike, at 18,000 miles, think I should attempt my first valve check/adjustment??? Never done it, but am game if you guys think it would be a good idea.....
tenover is offline
post #12 of 16 (permalink) Old 03-23-2013, 09:22 PM Thread Starter
tenover's Avatar
Original plugs after 18,000 miles....
tenover is offline
post #13 of 16 (permalink) Old 03-23-2013, 09:56 PM Thread Starter
tenover's Avatar
Good idea to apply dielectric grease to the the metal threads of the new plugs or not? Any other good tips before I put this thing all back together?
tenover is offline
post #14 of 16 (permalink) Old 03-23-2013, 10:45 PM
Your valve clearances should be checked.
Do not apply anything to spark plug threads: http://www.ngksparkplugs.com/pdf/tb-...1antisieze.pdf
Your spark plug ground electrodes are worn down and rounded off, which is normal at your mileage. Kawasaki recommends replacing them at every 7,500 miles.
They look a bit dark. Was your air filter very dirty and/or over-oiled?
http://www.rockauto.com/dbphp/x,cata...0,partnum,6289
post #15 of 16 (permalink) Old 03-23-2013, 10:49 PM Thread Starter
tenover's Avatar
Yes, it was very dirty, and I replaced it(air filter). Valve clearance check....Uggh. I'm scared. LOL
tenover is offline
post #16 of 16 (permalink) Old 03-24-2013, 01:04 PM
Be sure you have a 1/4" torque wrench before you start (bolts holding the cams take about 100 inch-pounds torque, which is VERY LITTLE - about 9 '/#) and you'll break them easily by over-torquing. Search the threads - lots of us have posted about doing it, one lister with LOTS of pics, very recently. Here's one I started: http://www.kawasakiversys.com/forums...read.php?t=902
