Wiring/Accessory help - Kawasaki Versys Forum
post #1 of 22 (permalink) Old 03-19-2013, 03:42 PM Thread Starter
tenover's Avatar
A couple years ago I installed those cheap, stick-on grip warmers to my 2009 Versys. I have them going to a wiring distribution block, then a relay. They are tapped into the tail light. I just bought a little 12v power adapter/cigarette lighter to install and use for charging my iphone. Will it be ok, power wise, to simply connect those wires to open spots on my distribution block? Just don't want to drain a new battery or have something not work....And do I, or "should" I install an inline fuse between the power outlet and the relay? Thanks.
tenover is offline
post #2 of 22 (permalink) Old 03-19-2013, 03:43 PM Thread Starter
tenover's Avatar
Actually, now that I look closer, I already have a 20a inline fuse between the relay and the battery....Should that suffice?
tenover is offline
post #3 of 22 (permalink) Old 03-19-2013, 04:45 PM
Baron650's Avatar
You should be good to go.
Baron650 is offline
post #4 of 22 (permalink) Old 03-19-2013, 04:51 PM Thread Starter
tenover's Avatar
Thanks. Ok, next questions...
1.) My distribution block has 12 screws/inputs. Five are already taken. Does it MATTER where I connect the new live and ground wires for the 12v outlet on the block?
2.) The outlet comes with huge "O ring" connectors. Can I just cut those off and install the smaller ones that will fit to the distribution block?
Here's a pic of the wiring distribution block as it stands.....
Thanks for your help.
tenover is offline
post #5 of 22 (permalink) Old 03-20-2013, 12:39 PM
Its difficult to tell for sure just from the photo but it would appear the 6 on the left are positive and the 6 on the right are earth, yes a basic crimp set should include all the bits you need to cut off the old connecters, strip the wires and crimp on new connectors, just make sure to watch a youtube video or read a guide to make sure youre doing it correctly.
RudiRulez is offline
post #6 of 22 (permalink) Old 03-20-2013, 08:17 PM
IF it 'blows', think about a 30A fuse, but IF a 30A blows DON'T go bigger till you discover why!
post #7 of 22 (permalink) Old 03-21-2013, 08:07 PM
Suggest you consider the FZ-1 relay/fuze-block. Several threads here that testify to its good performance and ease of use. Find it at
http://www.fuzeblocks.com/index.php?pid=5#faq80
ScottyNeal is offline
post #8 of 22 (permalink) Old 03-21-2013, 11:18 PM Thread Starter
tenover's Avatar
Looking at the picture I posted above.....On the postive side, on the upper half, there is that metal piece....If I connect the 12v power outlet to one of those remaining 6 positive terminals, do I need to remove that piece completely? Part way? Or just connect OVER that piece?
tenover is offline
post #9 of 22 (permalink) Old 03-23-2013, 01:30 PM Thread Starter
tenover's Avatar
Another question...I bought a standard "Trackside" 12v Power adapter. I'm going to need to extend the wires to reach the distribution block, and both wires are covered in a single heat shrink tube, so I can't tell what size the wires are. I know that the only wire I have is a bit smaller than what these are. Anyone know what size wires the stock ones are so I can go buy some?
Here's a link to an install page someone did on the exact model. I also see this:
"A power adapter requires a steady 12-volt DC potential so it needs to be wired directly to the battery (on bikes without a battery or an aftermarket stator it's unlikely that even rectified current will fall withing the range required to run must consumer electronic devices). The harness supplied with the Trackside unit is intended to serve this purpose but at around 20 inches in length it's far too short for most dirt bikes. Many installations will require lengthening the leads. "
Is this true? Should I hook it directly up to the battery instead of going to my distribution block/relay that's tapped into the tail light?
http://www.motorcyclejazz.com/motorc...er_adapter.htm
tenover is offline
post #10 of 22 (permalink) Old 03-23-2013, 03:29 PM
Your "distribution box" SHOULD be wired to the battery, with the tail-light ONLY 'triggering' the relay.
IF you go direct to the battery, be sure to put an inline fuse on the + wire. I suggest you add any wire to the short leads in 12 or 14 gauge.
post #11 of 22 (permalink) Old 03-23-2013, 04:01 PM Thread Starter
tenover's Avatar
Thanks. I just traced all the wires. Here's how it sits now. You got me worried that it is not hooked up correctly as it stands now, with heated grips only. If this looks right, I was hoping I could use one more neg. and one more pos. point on the distribution block to attach the new power adapter and be good to go. Just want to make sure it's safe to do it this way. Here's my super technical wiring schematic.....
tenover is offline
post #12 of 22 (permalink) Old 03-23-2013, 04:33 PM
Baron650's Avatar
That wire diagram looks right to me. You are not getting constant 12v DC power as the distribution block is now "switched" at the relay, only getting power when the bike is on. Not killing the battery when you leave your grips on is a good thing!
Maybe for an accessory plug that's OK, if so it looks like you have room on your block. Cut the big connectors off along with about an inch of wire. Go to the hardware store and match the size and get enough wire and some connectors that will fit your block.
Baron650 is offline
post #13 of 22 (permalink) Old 03-23-2013, 04:41 PM Thread Starter
tenover's Avatar
Thanks a LOT. Much appreciated. One last thing that I asked a few posts up but didn't get a reply on....
On the positive side of the distribution block, there is a "jumper plate" on the unused side. Should I leave that in place, cut it off only on the connection I'll be using, or take it off completely? See pic below. Thanks again. Piece of mind for sure...
tenover is offline
post #14 of 22 (permalink) Old 03-24-2013, 03:58 AM
post #15 of 22 (permalink) Old 03-24-2013, 12:55 PM
IF you are referring to the piece on the LEFT side of the 'block' that comes above it which looks to be on the + side - make DAMNED sure you protect it from 'shorting-out', or you could have a BIG fire right under your a$$ and jewels...! If there's a plastic cover over that area that probably protects it, but looking at the pic again - it appears to me that it's removeable.
I WOULD, however, cover it for protection from 'shorting'.
post #16 of 22 (permalink) Old 03-25-2013, 07:50 PM Thread Starter
tenover's Avatar
Can I just remove that piece or is it needed for some reason? It's just a "jumper" that bridges those three spare screws....
tenover is offline
post #17 of 22 (permalink) Old 03-26-2013, 01:08 PM
My suggestion is to remove that piece, and the 3 wires, then use your VOM between one-to-another of them to see whether or not they are connected.
That will tell you IF you need that piece (because they have to connect SOMEHOW).
post #18 of 22 (permalink) Old 03-27-2013, 10:36 PM Thread Starter
tenover's Avatar
You have me worried now. Would it be "Safer" to remove that block altogether and have the relay for the grips going to the battery and then ANOTHER relay for the 12v outlet also going to the battery(tapped off a different circuit)?
tenover is offline
post #19 of 22 (permalink) Old 03-28-2013, 11:43 AM
If you look at a commercially available fuse-block (I use the FZ-1 myself), you'll see that in normal use all points of contact are covered to obviate the chances of a short circuit.
I think you might be better off with something like that, safety-wise...!
post #20 of 22 (permalink) Old 03-29-2013, 01:55 PM Thread Starter
tenover's Avatar
This one?
http://www.cyclenutz.com/Fuzeblock-F...FZ-1_p_92.html
If I get this, I could remove my current relay, "fuse block" and inline fuse and replace it all with this single unit and just wire the grip heaters and 12v outlet into it and be good to go? Almost looks too easy
tenover is offline
