ECU Problem?? - Kawasaki Versys Forum
post #1 of 7 (permalink) Old 03-19-2013, 03:00 PM Thread Starter
viper3's Avatar
ECU Problem??
Hello,
I have 2010 versys with 39 K kilometers. I have had it 3 weeks.
I did not notice when I bought it the fan did not work, and I may have another problem. I have tested the fan it is dead. I also tested the power supply to the fan, the fuse was blown, I replaced it, but now as far as I can tell there is still no power to it. I have never seen the Temp light come on, should it come on to test when I turn the key on? I tried Reading the FI fault codes, but when I try that I get nothing, the FI does not flash at all, it does go on an off normally at key on. My fuel mileage is not very good either (46 imp or 38 US mpg)
Any ideas?
Thank you for reading
Wayne
viper3 is offline
post #2 of 7 (permalink) Old 03-19-2013, 05:03 PM
tenover's Avatar
How'd you get that?!??! Can you post pics? I'd love to see a 2020 Versys!
tenover is offline
post #3 of 7 (permalink) Old 03-19-2013, 06:32 PM
You'll get power to the fan only when the coolant gets hot enough.
invader is online now
post #4 of 7 (permalink) Old 03-19-2013, 09:24 PM Thread Starter
viper3's Avatar
that's 2010 ha ha
funny I guess there are two of us that are tenover
viper3 is offline
post #5 of 7 (permalink) Old 03-19-2013, 09:26 PM
Originally Posted by viper3 View Post
that's 2010 ha ha
post #6 of 7 (permalink) Old 03-19-2013, 09:30 PM Thread Starter
viper3's Avatar
yes I know, I idled it for quite some time, the rad was feeling quite hot, maybe I did not let it go long enough but I am not sure the temp light is working and I am afraid of overheat. I don't know how to test the light.
viper3 is offline
post #7 of 7 (permalink) Old 03-19-2013, 10:33 PM
You'd have to drain the coolant, remove temperature sensor, and test it in a pan of heated oil, as described in service manual which is in this forum.
