pc 5? - Kawasaki Versys Forum
post #1 of 13 (permalink) Old 01-14-2009, 10:52 PM Thread Starter
tomla's Avatar
pc 5?
does anyone know if dynojet is coming out with a pc5 for the V? seems mcsuperstore is advertising them as available for the 09 but not in stock...and also at $280.
tomla is offline
post #2 of 13 (permalink) Old 01-14-2009, 11:14 PM
Interesting... Dynojet's PCV is said to be available soon for the Versys at about $280.
Features:
* Reduced size from PCIIIusb (less than half of the size of PCIII)
* USB powered from computer (9 volt adapter is no longer needed for programming)
* 2 position map switching function built in (map switch not included)
* Gear/Speed input (allows for map adjustment based on gear and speed)
* Analog input (allows user to install any 0-5 volt sensor and build an adjustment table based on its input such as boost or temperature)
* With gear position input connected, the PCV is capable of allowing each cylinder to be mapped individually and for each gear (for example: on a 4 cylinder bike with a six speed transmission there could be up to 24 separate fuel tables).
* Unit has a -100/+250% fuel change range (up from -100/+100%). This allows more adjustment range for 8 injector sportbikes
* 10 throttle position columns (up from 9 on PCIIIusb)
* Enhanced “accel pump” utility (increased adjustment and sensitivity ranges)
Auto Tune for PCV (all models):
* “Auto Tune” kit will be available that includes Wide Band O2 sensor(s) and control box(es). It will plug directly into the PCV and allow automatic fuel adjustments.
* It can make a map for each gear, and on Harley Davidson models it can map each cylinder separately for each gear if needed. (basic settings would make one map for all gears)
* Each map cell is individually adjustable so you can specify an exact AFR value for each area if needed.
post #3 of 13 (permalink) Old 01-14-2009, 11:17 PM Thread Starter
tomla's Avatar
yea, it looks better than the pc3....I gotta call them and see what's up...
tomla is offline
post #4 of 13 (permalink) Old 01-14-2009, 11:18 PM
Dynojet PCV
post #5 of 13 (permalink) Old 01-15-2009, 12:01 AM
Red Herring's Avatar
That auto tune seems like a great idea.
Red Herring is offline
post #6 of 13 (permalink) Old 01-15-2009, 11:07 AM
hacktracker's Avatar
It may only be available for Supersports and Superbikes.
Don
"ride more, worry less"
2000 Honda VFR800 - Street
hacktracker is offline
post #7 of 13 (permalink) Old 01-15-2009, 12:21 PM
ZaethDekar's Avatar
Send a message via MSN to ZaethDekar
perfect for the V then, eh?? :-p
ZaethDekar is offline
post #8 of 13 (permalink) Old 01-15-2009, 06:11 PM
Haha... It is in fact said to be available soon for the mighty V.
post #9 of 13 (permalink) Old 01-15-2009, 10:07 PM
Looks like a few tuners may be going out of business. The ability to self-tune will really be great!
Don
post #10 of 13 (permalink) Old 01-19-2009, 03:38 PM Thread Starter
tomla's Avatar
I called them today. they have a part # already and expect them to be built in about a month.
tomla is offline
post #11 of 13 (permalink) Old 01-19-2009, 11:09 PM
look like i'm going to be the lucky one. i'm probably going to be buying my V in about one month.
sir_crackien is offline
post #12 of 13 (permalink) Old 01-20-2009, 12:07 AM
Crap. I just got the PCIII a couple months ago!
It's awfully nice, but the 5 looks better!
post #13 of 13 (permalink) Old 02-13-2009, 02:02 PM Thread Starter
tomla's Avatar
still not out
dynojet says it should be out in another month...but that's what they said last month.
tomla is offline
