need help diagnosing dead battery(?) - Kawasaki Versys Forum
post #1 of 32 (permalink) Old 03-13-2013, 09:43 PM Thread Starter
tenover's Avatar
I'll say first of all, I'm NOT familiar with electronics besides the very basics....
I have a 2009 Versys. It has the original battery. The only add-on I've done is basic "wrap around" heated grips that go into a fuse box....Did that years ago and have had no problems whatsoever...They are tapped into the tail light and have never given me any issues. My problem is, for the past couple weeks, the bike starts fine in the morning, I ride it to work(20 miles), and then when I go to start it in the afternoon to go home, it cranks but doesn't start. I just took the battery out of the bike after it failed to start the bike after not being ridden for 2 days, and the voltage reads 12.03. Dead battery? I have another one on order already, but I'm worried that it's NOT the battery and might be something else.....Once this old batter is charged and back in the bike, how can I find out where the actual problem is? Thanks.
tenover is offline
post #2 of 32 (permalink) Old 03-13-2013, 09:54 PM
King.Versys's Avatar
I think you've found your problem. Batteries start to go after four or five seasons. I would wait and see if all is well after you get your new battery. Think positive.
King.Versys is offline
post #3 of 32 (permalink) Old 03-13-2013, 10:01 PM Thread Starter
tenover's Avatar
Thx. Fingers crossed.
tenover is offline
post #4 of 32 (permalink) Old 03-13-2013, 10:11 PM
It does crank but does not start the second time in afternoon... Is your normal warmed up idle set to 1300 rpm? What's your mileage, and how old are your spark plugs?
post #5 of 32 (permalink) Old 03-13-2013, 10:15 PM Thread Starter
tenover's Avatar
Well, the battery show 12.54 after charging. I put it in the bike and tried to start it up. All lights and dash come on. When I push the starter button, it tries to turn over, but makes a "hiccup" sound......Hmmm......
tenover is offline
post #6 of 32 (permalink) Old 03-13-2013, 10:15 PM Thread Starter
tenover's Avatar
mileage is about 18,000 miles, spark plugs are originals. I'll try and post a video.
tenover is offline
post #7 of 32 (permalink) Old 03-13-2013, 10:16 PM
What's the output from your alternator. Maybe battery.
post #8 of 32 (permalink) Old 03-13-2013, 10:17 PM
You are well overdue for new spark plugs.
Is your normal warmed up idle set to 1300 RPM ??
post #9 of 32 (permalink) Old 03-13-2013, 10:20 PM Thread Starter
tenover's Avatar
It is stock, so I'm assuming "yes".
tenover is offline
post #10 of 32 (permalink) Old 03-13-2013, 10:28 PM Thread Starter
tenover's Avatar
Here's the symptoms.....
No Video
If the embedd doesn't work, here's the link to the video:
http://www.youtube.com/watch?v=eTPnm...ature=youtu.be
tenover is offline
post #11 of 32 (permalink) Old 03-13-2013, 10:46 PM
You have to be aware of what you're idling at. If it's not at 1300 rpm idle, you must set it to 1300 with your adjustment knob on the right. And I mean your normal idle once it's warmed up and settled.
post #12 of 32 (permalink) Old 03-13-2013, 10:50 PM Thread Starter
tenover's Avatar
But if I can't even START it, it's kind of hard to set the idling speed, no? Did you watch/listen to the video I posted?
Strange sound.
tenover is offline
post #13 of 32 (permalink) Old 03-13-2013, 11:44 PM
You're missing the fuel tank... Does it start with the fuel tank on, connected and hooked up? If not, try cranking while opening the throttle just a tad. Then check idle speed if it does start, and once it's warmed up.
post #14 of 32 (permalink) Old 03-13-2013, 11:48 PM Thread Starter
tenover's Avatar
Oh. My. Friggin. God.
Ok, I feel like an absolute idiot now. Yeah, it probably does! It's off getting painted with the rest of the parts. Geeeeez. Chalk this one up to plain STUPID. Thanks.
tenover is offline
post #15 of 32 (permalink) Old 03-13-2013, 11:49 PM Thread Starter
tenover's Avatar
I'll wait until the parts come back and it's gassed up. DUH.
tenover is offline
post #16 of 32 (permalink) Old 03-14-2013, 12:04 AM
Those gas fumes will do that to your brain.
post #17 of 32 (permalink) Old 03-14-2013, 12:08 AM Thread Starter
tenover's Avatar
LOL....yeah, between the gas fumes and glassing surfboards, I'm surprised I have ANY brain cells left! Thanks.
tenover is offline
post #18 of 32 (permalink) Old 03-14-2013, 12:13 AM
Replace your spark plugs while the fuel tank is off. Beside a likely idle adjustment required, new spark plugs will definitely improve your situation. Also clean and re-oil your air filter... Do you know how to do it properly?
http://www.rockauto.com/catalog/rafr...artnum=CR9EIA9
post #19 of 32 (permalink) Old 03-14-2013, 12:16 AM Thread Starter
tenover's Avatar
Thanks. Will do all of those things while the parts are off getting painted.
tenover is offline
post #20 of 32 (permalink) Old 03-14-2013, 12:20 AM
This would be a great time to check and adjust valve clearances if you haven't already... After all of that, you could synchronize your throttle bodies.
