these connectors are cool (or) what size of wires used in the Versys - Kawasaki Versys Forum
post #1 of 12 (permalink) Old 03-03-2013, 10:13 AM Thread Starter
Hello,
I planing some electrical projects to do before this coming riding season and I'm planing to use these :
http://www.ebay.com/itm/5pcs-ELECTRI...item4ab43ed085
as the splicing element (the t-type obviously).
but I'm not sure which size do I need. the circuits I'm planing to tap into are : Brake light, back running light, turn signal and maybe the front daytime running light.
anyone knows which AWG \ mm size are those wires ? would be a great help
ibonneau is offline
post #2 of 12 (permalink) Old 03-03-2013, 10:20 AM
invader is online now
post #3 of 12 (permalink) Old 03-03-2013, 03:14 PM
V-COASTER's Avatar
Originally Posted by ibonneau View Post
Hello,
h
I have used the posilock and positap connectors for my last couple of bike wiring projects and they work very well. Most of those wires you mentioned are 18 gauge.
www.posi-lock.com
2013 Versys1000
V-COASTER is offline
post #4 of 12 (permalink) Old 03-04-2013, 02:48 AM Thread Starter
V-coaster - thanks that exactly the information I needed. I didn't want to strip the wires to find what size they were.
Thank you.
ibonneau is offline
post #5 of 12 (permalink) Old 03-04-2013, 02:52 AM Thread Starter
I heard that Positaps are great but they're really not cheap and hard to come by over here in Israel.
I've ordered the T-5 from the above product and it appears to be very well made and high quality.
I'll share the actual functionality when I receive the correct size.
(I've misread the size chart)
ibonneau is offline
post #6 of 12 (permalink) Old 03-04-2013, 06:58 AM
As an electrician, I've used similar type connectors for splices. I'm not sure of how good these are, but the ones that I have used, I don't totally trust. There are barbs inside the connector that when shut, push thru the insulation of the wire to the copper wire inside. I have seen these barbs roll to the side of the wire and not make a good contact with the copper wire. I always squeeze the connector with channel locks to make sure. They are quick and you don 't need to cut the wire. This would be the up side.
wampuspacker is offline
post #7 of 12 (permalink) Old 03-04-2013, 09:22 AM
Lours_Polaire's Avatar
www.posi-lock.com
Also available here at webbikeworld
LOP
Lours_Polaire is offline
post #8 of 12 (permalink) Old 03-04-2013, 07:46 PM
I solder all connections meant to be permanent.
Those don't apear to be sealed so they leave the contact open to the elements and will eventually corrode enough to add resistance and potentially melt or cause fire if the connection doesn't outright fail.
DrewsBrews is offline
post #9 of 12 (permalink) Old 03-04-2013, 10:11 PM
My favorite tap in connector I've used is Posi-Tap
http://www.posi-lock.com/
davidg is offline
post #10 of 12 (permalink) Old 03-04-2013, 11:48 PM
Another thumbs up for posi products
post #11 of 12 (permalink) Old 03-05-2013, 01:05 AM
SauceyFeet's Avatar
I used these to wire admore lights on my givi saddle bags to my brake and running lights. http://www.radioshack.com/product/in...uctId=12515225
They were easy to install and haven't caused any problems yet, although it's been only a year. I picked them up for a few cents each at my local Radioshack.
SauceyFeet is offline
post #12 of 12 (permalink) Old 03-05-2013, 03:52 AM
Yeah used them for years, they are crap, sometimes they work sometimes they don't.
