12v air bed pump off 2017 650 - Kawasaki Versys Forum
Like Tree3Likes
  • 1 Post By SteveJ
  • 2 Post By Gerharz14
post #1 of 16 (permalink) Old 03-12-2020, 12:12 PM Thread Starter
Gerharz14's Avatar
I have no idea about this electrical stuff. If I am camping and need to pump up an air mattress, would my stock 2017 650 be able to handle a normal 12v air pump? Thanks in advance for any information.
Gerharz14 is offline
post #2 of 16 (permalink) Old 03-12-2020, 12:42 PM
How many amps does the pump require?
Should be marked somewhere on it.
post #3 of 16 (permalink) Old 03-12-2020, 12:57 PM Thread Starter
Gerharz14's Avatar
40 watts
post #4 of 16 (permalink) Old 03-12-2020, 03:44 PM
That would be 3.3 amps I would wire in a acc plug for it and leave the bike running when filling bed .Or try it @ home.If the battery does not run down you could do it without running bike. It depends on how long that pump is gonna run .40 divided by 12 =3.3
Smooth is fast.
foxpro is online now
post #5 of 16 (permalink) Old 03-12-2020, 09:02 PM
With the bike running, you should be able to handle the load. Fuse it anyway to prevent any undue incident.
post #6 of 16 (permalink) Old 03-12-2020, 10:19 PM
jaaklucas's Avatar
Not sure how many amps my emergency tire compressor/ inflator draws but that can also be used to inflate other stuff. Get one of those and you can fix a flat as well! My headlight is 36 Watts. I bet heated grips on high would draw 3 amps also.
jaaklucas is offline
post #7 of 16 (permalink) Old 03-13-2020, 09:20 AM Thread Starter
Gerharz14's Avatar
Thank you so much everyone for your answers!
post #8 of 16 (permalink) Old 03-13-2020, 11:34 AM
chid's Avatar
Not sure if the bike charges the battery at idle.
If not, you could actually run down the battery while running the engine and using the pump.
Versys 2015 Green
chid is offline
post #9 of 16 (permalink) Old 03-13-2020, 02:45 PM
Are you talking an air compressor or air blower?
A 12 volt air compressor will take quite a while to fill a mattress. The 12 volt air blower(designed for inflating mattresses, etc.) will be quite quick.
I carry both when traveling.
Gerharz14 likes this.
'15 KLE650LT
'98 KLR650
And most of Canada too, eh?
SteveJ is online now
post #10 of 16 (permalink) Old 03-13-2020, 03:18 PM Thread Starter
Gerharz14's Avatar
An air 12 volt air compressor will take quite a while to fill a mattress. The 12 volt air blower(designed for inflating mattresses, etc.) will be quite quick.
Air blower that has a 12v plug on one side designed to inflate the air mattress
SteveJ and foxpro like this.
post #11 of 16 (permalink) Old 03-15-2020, 08:41 AM
Nashcat's Avatar
Try one of these pumps for mattresses. Self contained, battery operated. Recharges from USB. Inflates or deflates. Iíve had mine a couple of years and it works great.
EDITED to remove link.
Search Amazon for flextailgear Max Pump
Looks like this. Black tape is over switch to prevent turning on, while packed. I have no idea why the picture is inverted.
File Type: jpg 6B6B3E39-5C0E-4320-B2FB-A7D59B924BE2.jpg (9.0 KB, 20 views)
Waitiní on the boatman
Nashcat is online now
post #12 of 16 (permalink) Old 03-15-2020, 08:49 AM
Link is non working
Smooth is fast.
post #13 of 16 (permalink) Old 03-15-2020, 12:49 PM
Try THIS:
https://www.flextailgear.com/
post #14 of 16 (permalink) Old Yesterday, 06:35 PM
I had a blower that recharged from a 12 volt plug in. I made the mistake of sticking it in the tank bag for charging going down the road. Due to a lack of air circulation it overheated and died. Just sayin'.
'15 KLE650LT
'98 KLR650
post #15 of 16 (permalink) Old Yesterday, 08:44 PM
Nashcat's Avatar
I charge my pump before I leave home. Itís good for a couple of air mattress and inflatable pillows, as well as helping deflate them. Donít really know how long the batteries last, since Iíve never run it down on a trip. I havenít used it since last August, and just tried it. Batteries still up.
post #16 of 16 (permalink) Old Today, 07:54 AM
That would work for shorter trips. Once or twice per year I take a 2-4 week tour.
Screwing with the D battery ones was not going to work. For me, the simplest model is the one that runs on 12 volts. I changed the end on mine to an SAE two pin connection to plug into the powered tank bag/Tender cord direct from the battery.
'15 KLE650LT
'98 KLR650
