Wattage output of the 650 alternator - Kawasaki Versys Forum
post #1 of 3 (permalink) Old 11-15-2019, 07:52 AM Thread Starter
I want to add some electrics to my bike. I've been searching for the max output of the alternator but i have been unable to locate any info. Anyone know the output wattage?
Thanks,
Cecil
Olcec is offline
post #2 of 3 (permalink) Old 11-15-2019, 08:16 AM
tennistime99's Avatar
https://r.tapatalk.com/shareLink/top...ink_source=app
Hopefully the link works...
Sent from my ONEPLUS A6013 using Tapatalk
tennistime99 is offline
post #3 of 3 (permalink) Old 11-15-2019, 02:21 PM
Max Output / 330 Watts / 14.2 VDC
Short answer is 330 Watts, by converting to LED city lights and if you have a 2014 or older Versys converting to LED headlight, you get a wattage gain by the reduction of those loads, however , this is only a good idea if you change to a series regulator, otherwise your shunt regulator will be seeing a load increase greater than designed by Kawasaki engineers,
https://www.kawasakiversys.com/forum...ng-stator.html
https://www.kawasakiversys.com/forum...on-thread.html
