Chain / Time to replace chain? - Page 5 - Kawasaki Versys Forum
 32Likes
post #81 of 87 (permalink) Old 09-03-2019, 09:28 PM
IImproper Chain Type
Originally Posted by Fly-Sig View Post
Isn't the design function of the rubber damper to contact the chain? Machining it off defeats whatever it does, good or bad.
I have seen members post a chain that deformed the rubber dampening, turns out it was the wrong chain. I posted those photos to show what my 2015 15T sprocket looks like. If you read what is posted on Fortnine , it does exactly what it was designed to do, reduce wear on the chain and sprocket, reduction in noise may be a added benefit, however I wear ear plugs.
post #82 of 87 (permalink) Old 09-03-2019, 09:38 PM
hawkerjet's Avatar
There are a lot more bikes without rubber dampened front sprockets than those with them and they work just fine.
One goal of the rubber damper is to reduce sound and vibration.
I machined my damper down in case it was causing extra heat generation in the chain.
The test ride felt and sounded just as it did before. I would check the temp if I had a Laser Non-Contact Infrared Thermometer. Just feeling it by hand is not too accurate.
Cookin Wid Gas
hawkerjet is offline
post #83 of 87 (permalink) Old 09-03-2019, 11:59 PM
Fly-Sig's Avatar
Originally Posted by PCX View Post
Thanks for the discussion here, after reading through i decided to change my sprockets. Where can I find Molybdenum Disulfide oil that I am supposed to put on the front socket nut? I found this product at my local autozone store, is this the same as what manual asks for?
https://www.amazon.com/Liqui-Moly-20...gateway&sr=8-4
Since I have polluted the discussion with something unrelated, I have one more question: The manual specifies torque of 122ft-lbs, I suppose this is after application of MoS2 (as opposed to dry torque)?
This is the moly I used. Mix it with new motor oil in the ratio per the manual. The stuff you linked to is some kind of mixture with other stuff than moly. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Fwiw I don't think it is really critical to get the ratio exact. The moly is there to keep some lube on the threads over time.
For the torque I think you want to use the lower number. 92 ft lbs? It was in one of these threads, perhaps earlier in this one. Since the threads are lubed you need to reduce the torque from the dry number. Again I don't think we are dealing with ultra precision here. In the old days all we had were those bending torque wrenches with a pointer, not the click style. The washer ensures the nut won't come loose. There is some potential for problems if you over torque, so I'd aim for the lower number rather than the 122.
onewizard, SteveJ and PCX like this.
Fly-Sig is offline
post #84 of 87 (permalink) Old 09-04-2019, 09:30 AM
I use the Honda chrome moly paste to put a thin film on the sprocket teeth on both sprockets and on the inside of the drive sprocket where it slides over the output shaft.
I believe that stuff is no longer available under the Honda brand.
I also used that stuff as a lube for the teeth on the final drive to wheel interface on my c-10 Connie. Very little wear showing at 230k miles. The stuff works and is excellent for high pressure metal gear contact areas.
PCX likes this.
'15 KLE650LT
'98 KLR650
And most of Canada too, eh?
SteveJ is offline
post #85 of 87 (permalink) Old 09-04-2019, 05:26 PM
EK520 SRX2 chain
So far I have about 23,269 kms (14,458 miles) on my EK520 SRX2 chain, lubed ONLY w/ WD40, and it has ONLY been adjusted FOUR FLATS (2/3 of a turn) in that time. I expect that it might get another adjustment BEFORE I head S to AZ next month.
post #86 of 87 (permalink) Old 10-09-2019, 11:34 PM
Lee R's Avatar
Hereís my front and rear sprockets, OEM at 19k miles.
Itís hard to see at the angle of the photo but the front has grooves worn in by the previous DID chains which I went through two of them. This EK has about 5k miles on it and is a cheap SRO6 oring model.
Iíve had rubber damped sprockets in the past on my Tiger 1050 and never had issues with chain life on that bike, they typically ran 20-25k miles per chain.
I keep slack at the loose end of spec never tight and lube the chain every other tank.
This EK doesnít run as hot as the previous two which was bizarre. I didnít have a heat gun but the chain on the NC700x when stopped at the same time was significantly cooler to the touch. This is going exact same speed and conditions.
I have a new set of chain and sprockets ready to go, an EK SRX2 which Iíve run in the past for over 20k miles so that will be the ultimate test to see if anything really weird is going on with my versys.
Regular non-dampened sprocket going on this time. Iíve run them on many bike and never had a bearing problem from them.
Iíve always heard they were for sound reduction. The Cush drive should buffer the chain slack being taken up.
This is my 4th chain drive bike and Iíve been riding over 100k miles so far and never had any weird chain issues like this. If i was a complete noob and overtightened them Iím sure Iíd know it by now.
Lee R is offline
post #87 of 87 (permalink) Old 10-10-2019, 05:40 PM
Looking at your pics - your countershaft sprocket is WORN-OUT, while your rear one is PROBABLY also WORN-OUT.
As the rear sprocket wears the chain wears INTO the sprocket, so for me the ONLY way to know for sure is to put the worn sprocket against a NEW one to compare the individual 'teeth'.
Here's my '08 rear sprocket after 56K miles!!!.
quexpress likes this.
Tags
chain, questions
